Intermittent power steering seizure
Old Dec 13, 2015 | 03:00 AM
Femtech's Avatar
Angry Intermittent power steering seizure
Lately the power steering on my '99 XJR started seizing momentarily while turning. Also after completing a 90 degree turn it would seize while straightening out, it feels like intermittent loss of power steering. The belt is intact and the fluid level is Ok, can somebody please help it is frightening whenever it happens.
Old Dec 13, 2015 | 08:34 AM
yeldogt's Avatar
Seize ... sounds more like the rack.
Without power the steering will move throughout it's range while the car is moving -- it's difficult while stationary.
Not something you can mess around with --
Old Dec 14, 2015 | 12:29 PM
Jhartz's Avatar
Lucas makes a product called power steering stop leak which renews worn power steering. Smoothed up my XJ8 and my granddaughter's Altima ps.
Worth a try before investing in a rebuilt rack with tie rods ~$600 plus labor and alignment.
Old Dec 14, 2015 | 06:01 PM
Mark SF's Avatar
It could also be something in the front suspension that isn't working smoothly - upper or lower balljoints. If you are very lucky, it might even be a tie rod end.
Old Dec 15, 2015 | 12:01 AM
Femtech's Avatar
Thanks for the suggestions guys, I am scared to drive it now, I will jack up the front end this weekend and look, I hope it won't need an expensive fix !
Old Dec 15, 2015 | 12:11 AM
plums's Avatar
Maybe.
I had it in another car for about a month in cold weather.
It got so thick that it blew a hose on startup one fine
morning.
Called the distributor, they paid for a new pump and
hoses no questions asked. The lack of a fight suggests
to me that it is a known problem they would rather not
publicise.
Old Dec 15, 2015 | 12:53 AM
Mark SF's Avatar
I think I would disconnect the tie rod ends from the knuckles.. Then you can rotate the tie rods, and both steering knuckles, independently. You can also move the steering rack.
Old Dec 15, 2015 | 10:11 AM
yeldogt's Avatar
Our Jaguars call for a low temp fluid -- it's dexron low temp fluid. Most of the additives will do just the opposite of what the system requires.
A mechanic should be able to tell if it's a power problem or if the rack is binding -- your wise to be careful. If it is the rack binding up --- it could just stick and that would be very dangerous.
Celticblood
Dec 19, 2015 12:36 PM
firenfix
Nov 25, 2015 07:16 PM
jandouglass
Nov 25, 2015 02:14 PM
EZDriver
Nov 25, 2015 10:51 AM
EZDriver
Nov 15, 2015 02:00 PM
