Jag getting some surgery - should I do anything else while its cracked open?
Old Apr 1, 2014 | 10:51 AM
mcm97's Avatar
Default Jag getting some surgery - should I do anything else while its cracked open?
Gents
Even after I did the valve cover gasket I could still smell burning oil. As it turns out I need new timing cam gaskets and crank seals (along with pinon seals and swaybar links but thats something else). So while its open should I look at anything else?
Old Apr 1, 2014 | 11:06 AM
RJ237's Avatar
Timing chains, guides and tensioners?
Old Apr 1, 2014 | 11:35 AM
WaterDragon's Avatar
ditto to RJ237
Old Apr 1, 2014 | 12:21 PM
mcm97's Avatar
those will be checked out, thats on the list
Old Apr 1, 2014 | 12:44 PM
Cabezagrande's Avatar
Heater hoses.
Old Apr 2, 2014 | 06:47 AM
jrb53's Avatar
While you are at it I would drop the oil pan and clean out all the crud and replace the gasket. you will be suprised at the muck in the pan
Old Apr 2, 2014 | 12:06 PM
mcm97's Avatar
Originally Posted by Cabezagrande
Heater hoses.
good call.
Also doing upper and lower rad hoses and water pump. Decided to go from plastic to metal since its apart
toronadomike
Jan 22, 2026 10:13 PM
way2far
Aug 31, 2022 09:26 AM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
allenman85
May 10, 2021 03:11 PM
davidladewig
Sep 3, 2015 06:32 PM
