Jaguar Maintenance and Repair Costs
Old Nov 25, 2018 | 08:22 AM
XJDanny's Avatar
My fuel pumps have never been replaced in my ‘02 XJR. I have 81k miles. Do they fail often? Is this a proactive thing I should take care of before they fail? $1100 sounds expensive.
Old Nov 25, 2018 | 11:12 AM
JagV8's Avatar
They need not cost so much but also mainly fail when the car is not used regularly.
Old Nov 25, 2018 | 04:51 PM
XJDanny's Avatar
Thank you, JagV8. I do use my car regularly so that makes me feel better. I guess I won’t replace them then since all is well right now.
Old Nov 25, 2018 | 04:52 PM
80sRule's Avatar
Originally Posted by XJDanny
My fuel pumps have never been replaced in my ‘02 XJR. I have 81k mikes. Do they fail often? Is this a proactive thing I should take care of before they fail? $1100 sounds expensive.
Really? Not much. Keep a good amount of gas in the car. That helps them as they won't tend to try to suck do so much crap through the in tank filter, and the pumps actually are cooled by the gas. If a fuel tank is more full when stored, corrosion from moisture is lessened too; preventing less crap to work the pump hard. That all said, they eventually fail and you just have to replace them.
Old Nov 25, 2018 | 06:13 PM
Alfred Firmani's Avatar
Replacing the in-tank fuel pump is a pretty difficult job. $800-$1,200 is par for the course. The OEM fuel pump is quite expensive in itself and decent aftermarket ones are around 300 bucks when I looked into it. From what I have been told they just fail without warning. I don't think you would want to replace it until it actually goes out.
Old Nov 26, 2018 | 02:26 AM
JagV8's Avatar
Any low volume luxury marque car is liable to be expensive to fix/maintain if you don't DIY.
This forum can assist with the DIY...
Old Nov 26, 2018 | 04:55 AM
yeldogt's Avatar
It's something to understand as a weak point - that way you are looking at the pumps when any odd engine operation occurs. With the R having two -- can complicate things. You can test them. There are various aftermarket pumps available -- some surprisingly inexpensive. It's important to understand that some require modification of the mount and may also not have the same electrical plug -- there are work arounds for both.
Some pumps just fail, others must start to bind and the output becomes unstable ....one additional issue is the wire harness in the tank. Some pumps must start to pull more amps and this overheats the wire or the connector at the pump. With the amount of labor required I went with the OE pumps and internal filters - I had them on hand when my independent started the job .. the harness to each pump is about $100 and the local dealer had them in stock. In my case the the wires were fine. But, it's not something you will know ahead of time and may need to be addressed.
I was not going to get involved with my independent trying to modify the parts -- I many have looked at it differently had it been a Jaguar specialist with many under his belt and long term experience with given aftermarket part. I keep my cars -- so this was not a get it back on the road for a year fix.
Old Nov 26, 2018 | 07:48 AM
  #28
XJDanny's Avatar
[QUOTE=yeldogt;1993337I was not going to get involved with my independent trying to modify the parts -- I many have looked at it differently had it been a Jaguar specialist with many under his belt and long term experience with given aftermarket part. I keep my cars -- so this was not a get it back on the road for a year fix.[/QUOTE]
It’s funny but I’ve had this car more than four years and regularly read this forum and this post was the first time I noticed the fuel pumps mentioned as something as a weak point and a rather expensive repair. I’m glad I’m aware of it now. Or maybe I’m not haha!
Like yours, my mechanic is not a Jaguar specialist so I like your advice regarding sticking with OEM parts if I need to deal with this issue. Thank you for the help!
Danny
Flighty
Oct 11, 2014 08:49 PM
MarylaLuna
XJ40 ( XJ81 )
20
Apr 25, 2014 01:12 AM
jess1023
Sep 22, 2012 01:06 PM
kgcarbon
Apr 9, 2012 11:27 PM
jeffn
21
Feb 19, 2012 12:40 PM
