Jaguar making popping noise from top of intake
Old Feb 3, 2011 | 11:39 PM
Bamaman's Avatar
I'm not a mechanic, and I'll just give you what the book says about these codes.
P1000 System checks not complete since last memory clear
P0300 Random misfire detected
P0304 Misfire detected – cylinder A4 (4)
Cylinder compression low
Worn camshaft / broken valve spring(s)
Fuel delivery pressure (low / high)
Fuel injector(s) blocked / leaking
Fuel injector(s) continuously open
Fuel contamination
Fuel injector circuit fault(s) (Injector DTCs also flagged)
Spark plug failure / fouled / incorrect gap
ECM to ignition module primary circuit fault (Cylinder misfire detected DTCalso flagged)
Ignition module ground circuit open circuit, high resistance
Ignition module / coil failure
P0112 IATS sense circuit high voltage (low air temperature)
IATS to ECM wiring open circuit or high resistance
IATS to ECM sensing circuit short circuit to B+ voltage
IATS failure (Intake Air Temperature Sensor)
Old Mar 1, 2011 | 08:00 PM
Glendoramike's Avatar
Run a compression test. Usually when there is poping in the intake manifold, it is from an intake valve not sealing.
Old Mar 1, 2011 | 09:18 PM
plums's Avatar
The banks are A and B with cylinders 1-4.
The tensioner replacement is full of risks for the careless or inexperienced.
Find out which bank had the tensioner was replaced.
If it is bank A, then looking at the cam timing is a good start.
xjrjag
May 21, 2026 09:05 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Sshenton1975
Aug 30, 2015 09:29 AM
Carl Cooper
General Tech Help
Aug 27, 2015 04:36 PM
