jaguar solenoid 8? P0175
Old May 14, 2014 | 05:28 PM
vincent661983's Avatar
ok, for those remember about my on going issue with the gear shifter
I am stilling get the "transmission fault" yellow light and I changed 2 shifter already with correct linear switch.
mechanic found the code P0715 and he said something called solenoid 8?
from my scanner I had before that code indicted system too rich (bank 2)
any one explains to me what I am talking about please?
Old May 15, 2014 | 04:26 AM
JagV8's Avatar
Maybe mech said wrong number? P0175 is a generic code you can look up anywhere (or JTIS for your specific car - try it!).
Old May 15, 2014 | 05:14 AM
sparkenzap's Avatar
P 175 means the bank is running rich. Maybe you misunderstood, or ...Maybe time for a new mechanic?
If it really is P175, try cleaning the MAF according to directions in the archive.
It would be helpful to know the year and model!
Old May 15, 2014 | 08:07 AM
any idea what is solenoid 8?
Old May 15, 2014 | 09:51 AM
RJ237's Avatar
If your mechanic is using a generic reader, and getting the interpretation from the reader instead of the Jaguar DTC summary, it's probably an error. Does you mechanic have a lot of experience with Jag's?
Old May 15, 2014 | 12:14 PM
no, he is a general mechanic so that is why I need forums opinion
Old May 15, 2014 | 02:04 PM
sparkenzap's Avatar
I THINK that code is a standard OBD code
Old May 15, 2014 | 03:38 PM
Jhartz's Avatar
Default P0175
Google OBD II code P0175. You need to clean your MAF sensor! Then try a can of SEA FOAM to clean the injectors. and reset the codes.
Your mechanic should know how to do this. But you might print the tech writeups you find on Google (I used DuckDuck Go). The second search listing was nearly perfect.
Old May 15, 2014 | 06:23 PM
Rlover's Avatar
throwing it out to you. I had a p0172 and a p0175. I found two vacuum lines off from the TB and the breather tube from the drivers side ( USA ) front of the valve cover was clogged. clean your MAF with CRC and apply dielectric grease then snug in place with two wire ties on each side. this worked for me..
Old May 17, 2014 | 03:00 PM
ok, im at friends shop now. the transmission fault seems from engine speed sensor.
anyone has more detail for me.
jim,if you read this. do you have the pdf file for instruction.
thanks
P0715 Mercedes-Benz - Transmission Input/Turbine Speed Sensor Circuit Malfunction
Possible causes
- Faulty Transmission Speed Sensor
- Transmission Speed Sensor harness is open or shorted
- Transmission Speed Sensor circuit poor electrical connection
What does this mean?
When is the code detected?
Diagnostic Trouble Code (DTC) P0715 is detected when TCM or ECM does not receive the proper signal from the sensor.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible shifting problems
P0715 Mercedes-Benz Description
The input speed sensor detects the primary pulley revolution speed and sends a signal to the Transmission Control Module (TCM) and Engine Control Module (ECM).
Old May 17, 2014 | 03:28 PM
test point's Avatar
On the ZF transmission the P0715 would probably mean an electrical connection fault at the rear of the transmission or between there and the TCM. The sensor itself seldom fails.
Old May 17, 2014 | 04:27 PM
sparkenzap's Avatar
Vincent-
I do not know if you have realized this yet, but your original post says the code was P-0175. P0175 does not equal P0715. That may be why you think we are all crazy and we started thinking the same of you!
Anyway, it sounds like you are on the right track for P715!
Old May 17, 2014 | 04:50 PM
my mistake guys. so we are on track now. fyi mine is mb 5 speed tranny xjr not NA zf.
let's talking
Old May 19, 2014 | 05:02 PM
Transmission Issue - Code P0715 - Mercedes-Benz Forum
Old May 19, 2014 | 05:06 PM
Guys, I rarely but this time I am really running out of the clue and really appreciate any input
my instinct still tells me there should be NO problem on the transmission itself but some electrical issue around it. because all of those issue happened since I cracked the original assembly and changed another 2 but issue persisted
what is the solution of error code P0715
Old May 19, 2014 | 05:08 PM
so far, I found it is related to engine speed sensor, transmission conductor plate and before, the shifter linear switch
I just spoke with my friend who works as a mechanic for M Benz
he mentioned about valve body circles board 722.6 mercedes
Old May 20, 2014 | 12:03 AM
sparkenzap's Avatar
Vincent:
OK, I think by now you have realized that the codes for a Mercedes are not going to be the same as your XJR- The gearboxes are the same, but the control modules are different. Frankly, when you started quoting the mechanic who was telling you some crap about "solenoid 8", I did not care to get in a pissing match with a professional (which I am most definitely NOT!).
Anyway, here is the code P0715 possible causes line from the JAGUAR service manual. Notice there is no mention of any solenoid. It sounds as if either a speed sensor switch, or a wiring connector, or maybe even the transmission module might be the problem. It also implies that the sensor has a "hard error" as opposed to an unreasonable value error, so it can probably be diagnosed with a DMM.
Good luck.
File Type: pdf
Old May 20, 2014 | 09:37 AM
I will take my Jag to the specialist Thursday, the shop is called"XJR auto repair", I hope they really mean business
Old May 20, 2014 | 09:51 AM
sparkenzap's Avatar
Heh, heh! You would hope, wouldn't you ?
Old May 20, 2014 | 11:05 AM
i can tell you guys it is a very stressful thing that taking some much efforts fixing cars all the time
