Jaguar XJ8 Odometer Not working
Old Jul 15, 2013 | 08:21 AM
MrJagXJ's Avatar
Default Jaguar XJ8 Odometer Not working
Just bought myself my first Jag - an XJ8 '98 3.2.
Only problem with it is the odometer isnt working. Its just blank so i cant see anything on the screen. The rest of the instruments are working fine, speedo etc..
Does anyone have any ideas what this may be? The lid to the fuse box in the engine bay is also missing so i cant check which fuse it is that may be linked to it.
Last edited by GGG; Jul 15, 2013 at 08:56 AM. Reason: edit typo in thread title so it appears in searches
Old Jul 15, 2013 | 08:30 AM
MrJagXJ's Avatar
spelt odometer wrong on the title, ooops
Old Jul 15, 2013 | 08:38 AM
WhiteXKR's Avatar
The LCD is a plug in module inside the instrument cluster. Chances are it has failed.
You can replace the entire instrument cluster, but you will have to match up the exact part number and software version, plus the odometer reading will not be correct for your car.
I would recommend instead finding the cheapest used instrument cluster for a '96'-'03 XJ on ebay, and just swapping out the LCD module inside the cluster.
Old Jul 15, 2013 | 09:10 AM
Welcome to the forum MrJagXJ,
+1 to the LCD Module. You don't want to get involved in swapping the full Instrument Pack if you can possibly avoid it.
I've edited the typo in your thread title so it appears in searches.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jul 15, 2013 | 09:11 AM
MrJagXJ's Avatar
is it not possible just to be a fuse or something simple like that? want to explore all the options before before i start buying new bits.
Also does anyone have the engine bay fuse box layout?
Old Jul 15, 2013 | 09:19 AM
WhiteXKR's Avatar
The LCD is not fused separately from the rest of the instrument cluster.
Old Aug 5, 2013 | 09:08 AM
MrJagXJ's Avatar
So i took out the instrument panel to change the bulbs at the back and it looked like some fluid had been spilt back there. Question i have does anyone know how hard it is to disconnet the LCD unit from the instrument cluster?
Old Aug 5, 2013 | 11:39 AM
WhiteXKR's Avatar
To get to it you need to remove the back cover of the cluster and unplug the small white ribbon cable connectors. Then remove the front bezel and unplig the red LCD connector and remove the circuit board. See steps 4-9 of the attached document to see some hints.
At ths point it would be easiest to just replace the entire dial assembly including the LCD with the one from the the donor cluster. If you choose instead to remove the LCD alone, you need to peel back the bottom part of black plastic dial label, which is attached with adhesive to get the LCD free.
MJ'S Jag
Nov 10, 2022 08:14 AM
johnnie ryall
Oct 19, 2015 09:44 PM
MarathonJohn
Sep 3, 2015 07:59 PM
Will P
Aug 27, 2015 06:52 PM
souldoubt
Aug 25, 2015 08:15 PM
