Jaguar Xjr cooling system
Old Mar 28, 2014 | 06:39 PM
Jagblack's Avatar
Default Jaguar Xjr cooling system
Hello,
i'm searching for a map of the cooling system of a xjr 98.
I'm so sorry if i make some mistakes in English but I'm from Poland.
thanks,
Raphael
Old Mar 29, 2014 | 12:01 AM
xjay8's Avatar
Originally Posted by Jagblack
Hello,
thanks,
Raphael
Greetings Raphael...perhaps this may help ;o)
Radiator and Hoses - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
Should give you are fair idea of whwre most of the components are.
Old Mar 29, 2014 | 08:46 AM
jimlombardi's Avatar
I pulled together the following XJR Heating & Engine Cooling diagrams, images and photos.
When the JPEG webpages open, click on the image to get a larger view of the image.
First JPEG is the XJR Engine Cooling & Heating System Components Diagram with Components List:
https://www.dropbox.com/s/04ne9h6o7u...Components.jpg
Next 2 JPEGs show the Images and Photos of the components:
https://www.dropbox.com/s/qpxxub3zhp...images%201.jpg
https://www.dropbox.com/s/b2d96yuz3m...images%202.jpg
Also a JPEG showing the Coolant Expansion Tank and the Recovery Tank:
https://www.dropbox.com/s/pr40evamr6...20Cover%29.pdf
Jim Lombardi
Old Apr 30, 2014 | 07:41 AM
Jagblack's Avatar
Hello guys,
thanks for your posts. My problem with the cooling system got more complicated than I had thought. It's the well known hose between the engine and the supercharger. So my question is, which hoses do I have to change? (I mean I need the number to order it). Do you prefer to change some other parts which I can combine with this special operation?
Best wishes,
Jagblack
Old May 2, 2014 | 11:43 AM
Jagblack's Avatar
I ordered yesterday this things:
- AJ83970
- AJ87634
- NNE3946CA
- NCA3976AD
- waterpump
- thermostat
Which gaskets do I need?
Should I order anything else for this ''operation''?
regards,
Raphael
BrentGardner
29
Dec 16, 2024 12:13 AM
JakeJagg11
Sep 3, 2015 07:36 PM
aquifer
Aug 29, 2015 04:54 PM
BlacXJRcat
Aug 28, 2015 07:10 AM
Zues
Aug 27, 2015 12:02 AM
