Jaugar XJ8R.1998
Old Nov 20, 2017 | 06:00 PM
Mac Mughal's Avatar
Default Jaugar XJ8R.1998
Hello I still have problem with my jag gearbox changed oil / filter still the same problem fault codes PO730 & PO780 and gearbox light comes on gearbox fault any one knows what is it.once car goes its fine could drive all day gears change fine stop for hour than problem no gear change or want go forward than switch it of restart its ok somes times do few times swith of restart before you can drive it I dont think there is fault in gearbox may be gearbox ECU
Old Nov 20, 2017 | 06:28 PM
Highhorse's Avatar
How did you measure your fluid to determine your level and how much did you put in? It sounds like your a tad shy of the proper level.
Old Nov 21, 2017 | 01:30 PM
Mac Mughal's Avatar
Default Jag XJ8R
Hello gearbox oil was checked/changed by Jaugar dealer.
Old Nov 21, 2017 | 02:46 PM
Jhartz's Avatar
Wow: a keyboard without a period. Dude, your description of the issue is really hard to read without punctuation.
I would suggest that you take it back to the dealer who changed the fluid and filter. I agree with Highhorse, sounds like you are low on fluid. But the dealer's diagnostic software can read the fault codes.
Old Nov 21, 2017 | 05:30 PM
Highhorse's Avatar
Where does it say that in your OP? With responses like that I guess we can simply ignore you.
Old Nov 22, 2017 | 04:48 AM
Sean B's Avatar
Mac there is an issue with the transmission control wiring seal, the trans fluid can creep up the harness and cause these faults - you'll need to get this checked out.
Old Nov 23, 2017 | 05:40 PM
Mac Mughal's Avatar
Hello Sean thanks for advice I will look in to this problem
pishposh
Apr 12, 2025 06:49 AM
unicorn
38
Jul 31, 2023 03:19 PM
Johnken
Oct 5, 2017 05:34 PM
jlindy
Dec 9, 2011 09:01 AM
