JTIS spec's ? Are Disc rotors HANDED left /right?
Old Jul 18, 2013 | 11:53 PM
osyris's Avatar
Default JTIS spec's ? Are Disc rotors HANDED left /right?
Im about to replace the disc rotors on my 1999 xj8 4.0 LWB.
I have 305mmm discs, non-brembo, just standard.
I refer to the JTIS software and the similar pdf version I have, it says
"check wheel bearing end float, refer to specification section 204-01...check Disc Runt out refer to specification section 206-03"
WHERE ARE THESE SPEC's LOCATED???...cannot find them, no numbers anywhere
(new discs just say 0.1mm max run out.. but whats jaguars measure?)
ALSO are the standard discs left or right handed?.. the 2 front and 2 rear ones I bought new have a slice of metal about 2 inches long machine cut out of the edge along the vents?
Would this be due to balancing or something?... or are they trying to mark the left/right ones by doing this as on the brembo's which are indeed handed and have a groove I believe to indicate left side.
best regards
Peter
Old Jul 19, 2013 | 12:20 AM
xjay8's Avatar
Peter, standard rotors are not 'handed'.
That machining would just be for balancing.
As for specs...can't say but these rotors usually wear quite well and can be refaced at least once.
The big thing is making sure the mounting faces are both clean and free from any corosion
as this will tend to 'throw' the rotor from true running.
Makes sure there is a smear of anti-sieze applied to surfaces and just bolt up.
Old Jul 19, 2013 | 05:45 AM
osyris's Avatar
what type of anti-sieze are you referring to .. ? I was thinking some high temp silicone grease or something applied to the mating surfaces.
However I am all ears to any specific recommendation.
I painted the new disc rotors, being sure NOT to paint the mating surface (inner on disc) nor the pad areas.. took me all day to carefully tape and paint them up with a aluminium high temp caliper paint... NOW I will have to the CALIPERS themselves.... the fun never ends!!
SO what type of grease anti seize compound does one apply to the mating surface (hub to disc?
Any idea on the SPECS for end flota/run out from JTIS???. cant locate the numbers
best regards
Peter
Old Jul 19, 2013 | 05:56 AM
jimbov8's Avatar
I use "copper crest" or sometimes called "copper slip". Smear it on the back side of the brake pads before fitting.
When you rebuild it is also a good idea to use the same stuff on all bolt threads. Just makes it easier to get off the next time.
Never a squeak out of mine.
Old Jul 19, 2013 | 07:45 AM
Originally Posted by osyris
.......... I refer to the JTIS software and the similar pdf version I have, it says "check wheel bearing end float, refer to specification section 204-01...check Disc Run out refer to specification section 206-03"
WHERE ARE THESE SPEC's LOCATED???...cannot find them, no numbers anywhere ..............
You will need a Dial Gauge to measure run out. Here's the specification from JTIS (arrowed in red - click on the image to enlarge it):
JTIS spec's ? Are Disc rotors HANDED left /right?-brake-disc-runout.jpg
Here is the procedure for the Front Discs:
JTIS - X308 Front Brake Disc runout Check.pdf
And for the Rear Discs:
JTIS - X308 Rear Brake Disc runout Check.pdf
This information is across three different 'brake' sections in JTIS.
Old Jul 19, 2013 | 08:00 AM
osyris's Avatar
Graham....
which section did you find this in in JTIS?... It says to refer to 204-01 but when I go to that there is nothing there... how /where did you find it...pages numbers please.
I have the dial gauge... how about hub bearing float specifications???
MANY thanks
Peter
aholbro1
Dec 29, 2024 06:46 PM
Richard_gib
Sep 12, 2015 07:08 PM
timm525
Sep 8, 2015 07:57 PM
JagLove86
Sep 6, 2015 10:36 PM
pegasus3710
Sep 5, 2015 09:40 AM
