Just bought an XJR - is this noise normal?
Old Sep 10, 2023 | 09:28 AM
asjdhsajhdfj's Avatar
Default Just bought an XJR - is this noise normal?
There’s a subtle ticking sound.
File Type: mov
Old Sep 10, 2023 | 10:45 AM
electrovolt's Avatar
Normal for me.... Is oil change correct ????
Old Sep 10, 2023 | 12:45 PM
Addicted2boost's Avatar
I can say that it doesn’t sound abnormal. If you just got the car, just drive it and continue to monitor it.
Replace that full load breather that’s held on with zip ties.
Old Sep 11, 2023 | 12:19 AM
Peter_of_Australia's Avatar
I don't know, this does not sound right to me.
It's something I do not know yet: It it possible to adjust the valves somehow on that XJR?
Is sufficient engine oil in the car?
And another idea, even though far fetched: Does the petrol in the tank have a minimum of 95 RON octane (=91 US octane)?
(You don't say in which country you are...)
Is the fuel fairly "fresh" or is the fuel very old and has it gone off?
Last edited by Peter_of_Australia; Sep 11, 2023 at 12:24 AM. Reason: added another idea
Old Sep 11, 2023 | 03:51 AM
Oil is close to max.
I would not know. The fuel is fresh (a good 50L used)
Thanks for pointing that out.
There are new sounds:
1. When driving and turning left, a knocking sound is heard on the front left side.
2. A small grinding sound when driving 10mph+.
Old Sep 11, 2023 | 08:07 AM
mayhem's Avatar
Is this the XJR you posted about in the other thread that you couldn't really inspect properly but opted to take a chance on a bid?
Grinding noise while driving was a rear wheel bearing in my car.
Knocking sound when turning left could be some rubber suspension bits that need replacing. Strut mounts, ball joints, control arm bushings...could be many things. You need to get it up on jack stands and explore it, or if you're not so inclined, take it to a mechanic you trust.
For the ticking sound, I'd agree that it might be from sitting. Drive it and get a few tanks of fuel through it. Keep checking all the fluids and make sure its not losing any coolant or oil especially.,
Old Sep 12, 2023 | 11:48 AM
Sean B's Avatar
I think the noise is injectors? Run a can of BG44K through the fuel system. They all do it.
Old Sep 12, 2023 | 03:29 PM
Jhartz's Avatar
I think it sounds normal. After following up on Sean's suggestion (or any really good fuel system cleaner, SeaFoam, Gamout, Lucas' best, or whatever they sell in your country, since BG44K is often hard to find), you might change the oil too. I think if you use a mechanic's stethoscope or a long dowel, you will hear injectors . . .
Old Sep 14, 2023 | 06:51 AM
oddly enough, I didn’t hear or feel any of this when going for the test drive. As long as the engine is running fine, I can deal with the other sounds.
I will head down to a specialist sometime next year as this car won’t be doing many miles.
It will, however, get a professional underseal.
Stuaseman
Jun 17, 2022 09:49 PM
JMorris
Nov 29, 2021 10:03 PM
metoymi
May 5, 2021 01:56 PM
Tomwhite
Mar 31, 2020 09:25 AM
ras
Sep 24, 2007 05:08 PM
