key fob, seat and stearing weel programing
Old Feb 11, 2009 | 09:26 AM
chupacabra's Avatar
Default key fob, seat and stearing weel programing
Hi all, can anyone explain me how to program my seat so it goeas back when i open the door or take the key out (ignition). when i took the car it was working good, but after i changed batery only the stearing wheel moves.... and is it posible to program the fob to close the open windows? it works with the key if i close the car with the key and hold it for few seconds the windows go up....
Old Feb 11, 2009 | 06:30 PM
JackJohn's Avatar
Your description refers to the Global Open and Global Close function. Mine works as you describe and it is my understanding that there is no way to use the fob to do a Global Close, this can only be done with the key.
Old Feb 12, 2009 | 08:49 PM
Pied's Avatar
To make the steering column and seat retract after taking out the key, turn the rotary switch on the left side of the column surround to the AUTO position.
The remote cannot roll up the windows and sunroof but if you hold the unlock button for several seconds I believe the windows and sunroof will open - handy if the interior of the car is hot.
Old Feb 13, 2009 | 02:27 AM
chupacabra's Avatar
it's olways turned to auto position but still only the stearing wheel is working
Old Feb 13, 2009 | 04:58 AM
Real_Tech's Avatar
After you changed the battery did you reset the memory positions of the seat?
Old Feb 13, 2009 | 08:58 AM
chupacabra's Avatar
yae but its strange, every time i program the seats and i try to push one of the buttons (1, 2 or 3) the seat goes different then i have programmed it.... maybe its faulty....
Old Feb 13, 2009 | 09:47 AM
joey4420's Avatar
I have read on here you can swap the drivers seat and passenger seat control unit and this may fix the issue. I hope so, because I have a similar issue, driving me crazy after my wife drives.. I have to reset the seat the mirrors oh the agony. Ok, not that bad, but since it does have the option it is irritating.
Old Feb 13, 2009 | 09:55 AM
Pied's Avatar
Ok, try this procedure:
Set the seat, steering, and side-view mirrors to the desired position.
Press the memory button, press the #1 button, then press one of the alarm remote buttons. After pressing the #1 button and the remote button there should be an audible chime. Then move the seat and mirrors to a different position. Now lock and unlock the car with the remote and see if the seat returns to the position you set. Good luck!
Old Feb 13, 2009 | 10:45 AM
chupacabra's Avatar
thanks, i'll try that... bu what i miss the most is that when i open the dor or take out the key the seat goes back and the wheal goes up so it's easy to get in (i'm tall) and now when i't s not working it drives me crazy
peterg19
Feb 10, 2023 09:02 PM
Clamdigger
Sep 12, 2015 03:43 PM
jfitzoz
Sep 7, 2015 04:28 AM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
