Key will not program/No crank
Old Dec 13, 2007 | 11:45 AM
bigdreams05's Avatar
Default RE: Key will not program/No crank
It has to be programmed at the dealer if I'm not mistaken.
Old Dec 13, 2007 | 02:18 PM
P1260-THEFT Detected, Vehicle Immobilized.
Sounds like you need a trip to the dealer. BTW, how does autologic help you in programming the key fob?
Old Dec 13, 2007 | 08:19 PM
Welcome Brad...................sounds like you need a treip to the dealer mate unless anyone knows different?
Jim
Old Jan 6, 2008 | 05:35 PM
FactoryJaguarTech's Avatar
We have outside shops that prgramme keys using Autologic. Keys for 98-2003 have been known to have bad chip. I would return them and get them recut. Also who cut them? Dealer or somewhere else. Look furthest end away from key blade and see if there is a raised spot. That is the chip. If not there, that would be your problem. And just a further note, you can indeed programme remotes for all jags except S-Type or new X150 without trip to dealer and with no tools. All done thru ignition barrel and light flash sequencing. If you want the info, email me and I will tell you.
Old Dec 12, 2024 | 06:22 PM
claw2953's Avatar
I HAVE A 1999 XJR AND DEALER says they no longer do this old but they gave me this part number LJA2610AA and i dont know what to do so any tips would be appreciated carrdan@live.com thank you
Old Dec 13, 2024 | 02:20 PM
Jhartz's Avatar
Not clear whether your issue is the key FOB needs programming or the key. For the key: You need to find an independent technician or locksmith that has the software to reprogram.
Old Dec 16, 2024 | 05:48 PM
Tech_JLR's Avatar
Where are you located?
Old Dec 16, 2024 | 06:43 PM
vincent661983's Avatar
Just find another dealer. I went to Jaguar Manhattan 2 years ago and they could still do it. Thought they charged me one hour of dealer mechanical.serive rate..330 plus tax
JWheeler
Nov 22, 2019 08:28 AM
Tipptone
Oct 6, 2015 11:32 AM
dieseldoc
Sep 28, 2015 01:17 PM
Jzar
Sep 27, 2015 02:55 PM
BSM
Sep 25, 2015 05:00 PM
