Killer Chill for an XJR
Old Nov 9, 2013 | 10:03 AM
jaguarcraver's Avatar
Default Killer Chill for an XJR
Anyone familiar with the Killer Chiller setup? If so, what model do you ask for when ordering, and do you need additional hardware to install in an XJR Jaguar? They don't appear to have one ready-made for an XJR, a was curious as to what was needed to install it. Thank you for your time, Louis
Old Nov 9, 2013 | 10:45 AM
danielsand's Avatar
I will be the first to admit,......I've never even heard of it. Pls elaborate,....what is it, what does it do, etc. I'm here to learn.
Old Nov 9, 2013 | 11:37 AM
It's a system that is plumbed into the air conditioning on cars and cools them significantly. I have seen some XKRs on here that have pictures of moisture
forming on the intercoolers with the Killer Chiller installed. Trying to find out what I need to install a kit on my car.
Old Nov 9, 2013 | 01:05 PM
Jhartz's Avatar
It chills the super charger cooling system to keep the ECU from retarding the ignition at full throttle during drag races (or blower pressure up so you can outrun ME 109s to stay lucky!).
Old Nov 9, 2013 | 04:50 PM
JgaXkr's Avatar
This is how cold you can get the charge coolers with a Killer Chiller. If you call & speak with Joe @ Kincaid Performance he will set you up with what you need. I strongly recommend you eliminate the radiator for the supercharger & replace it with a tank. You should also isolate the cooling system with a second reservoir & pump.
Old Nov 9, 2013 | 07:42 PM
Jgaxkr, do you have any preferences on a brand of reservoir and pump? I am definitely interested in pursuing this option.
Thank you so much for your input, Louis
Old Nov 9, 2013 | 08:55 PM
JgaXkr's Avatar
I just used a Jaguar reservoir from an XJ8. The second pump is a Bosch Pump. The tank was made by my local fabricator.
Attached Thumbnails Killer Chill for an XJR-014.jpg   Killer Chill for an XJR-killerchiller014.jpg
Old Nov 22, 2013 | 12:09 AM
Catenaccio's Avatar
That is an incredibly detailed engine bay. My compliments.
Old Nov 22, 2013 | 01:35 PM
dboydman86's Avatar
Amazing engine bay and killer setup you have there!
Old Nov 22, 2013 | 03:16 PM
vincent661983's Avatar
JGAXKR, where sourced you the carbon fiber cover? very thing in the picture is like ****...blood is running hot now !!!
Old Nov 24, 2013 | 08:30 AM
popeye68's Avatar
Damn .. inspiring pictures !
Old Mar 8, 2014 | 08:17 PM
TrekGTO's Avatar
Alternatively you can run an automatic diverter valve that will bypass the heat exchanger when AC is on and use the H/E when AC is off.
Old Mar 9, 2014 | 08:42 AM
JgaXkr's Avatar
The climate control system is designed to not be turned off so your a/c is cycling off & on even in the winter.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
moff1959
Sep 26, 2015 05:35 PM
