Leaking P/S Return Line
Old Jun 30, 2017 | 10:34 AM
KidRock'n's Avatar
Default Leaking P/S Return Line
Good morning, gents
Came home from a recent trip out west to find the 100 sitting in the driveway leaking some kind of fluid. Got it up on the hoist to discover that the rubber line is cracked and leaking right where part #10 is located on this diagram, to the front of the clip/coupler.
My question to you is, is this repair as simple as disconnecting that clip, sliding a replacement chunk of hose on there, and clamping it back down again - or does this necessitate a complete replacement of the line and cooler? Only place I could find it was the dealer for $525+HST.
As always, your insight is appreciated.
Cheers,
David
Old Jun 30, 2017 | 12:24 PM
Highhorse's Avatar
Do you have a hydraulic hose company close to you? If so, you should be able to run it over to them and have them refit it in about 30 minutes and it shouldn't cost more than $75-100.
Old Jun 30, 2017 | 01:01 PM
KidRock'n's Avatar
As a matter of fact I do - I worked there in highschool! If I can repair the line via this method, that seems like a no-brainer! Thanks for the insight!
Old Jul 1, 2017 | 03:05 AM
Addicted2boost's Avatar
You also might be able to disconnect that hose where it's leaking, cut that plastic quick connect off, slide it back on that metal tube and use a couple hose clamps. It's just a thought.
Old Jul 1, 2017 | 06:16 AM
Robert Laughton's Avatar
Hi David,
If you are stuck, I'll have a used one in my yard of parts cars.
I'm in the Great White North too!
Rob
Old Jul 1, 2017 | 07:06 AM
KidRock'n's Avatar
Originally Posted by Robert Laughton
Hi David,
Rob
Hi Rob, that's great to know! Whereabouts are you located?
Old Jul 2, 2017 | 01:35 PM
I'm in Niagara area Ontario.
Rob
Old Jul 2, 2017 | 10:50 PM
KidRock'n's Avatar
Rob
Perfect! I'm in Hamilton. I'll definitely let you know if I need it. Thanks in advance!
