LED brake light
Old Oct 17, 2018 | 06:32 PM
omgimali's Avatar
Default LED brake light
Will i need a load resistor if I put a LED Tail light/Brake light? or should it be fine?
Old Oct 17, 2018 | 06:38 PM
King Charles's Avatar
The "error free" LEDs have a built in resistor.
Old Oct 17, 2018 | 07:40 PM
SteveXJ8L's Avatar
"Maybe....."
I just bought a set of brake/tail lights from SuperBrightLEDs. The part number I got is 1157-R26-CBT. Their website says these lights are CAN Bus compatible, and specifically said they will work on my 2000 XJ8L. Well, not exactly..... They do work, and I like the nice bright light. However, every time I hit the brakes I get the "CHECK REAR LIGHTS" warning in the dash display. I emailed SuperBrightLEDs about it, and their response was "you have to install a load resistor on each bulb..."
So now I guess I need to pick up a pair of resistors.....
As Charles said, there are lights out there that have the resistor built-in. I thought what I was getting would be that type, but apparently not. If in doubt, ask the vendor. Or plan on spending an extra few bucks for resistors.
Steve
Old Oct 17, 2018 | 09:56 PM
omgimali's Avatar
how hard is it to put resistors
Old Oct 17, 2018 | 10:15 PM
Not complicated, but tedious with small bulbs & tiny resistors. Intricate finger work to twist or solder them on.
Old Aug 22, 2021 | 12:16 PM
ptjs1's Avatar
Posted in error.
Apols
CryptoCowboy 01
Apr 25, 2019 01:04 AM
Windigo
Feb 18, 2019 03:31 PM
hammad2004
Aug 28, 2018 06:16 PM
vincent661983
Apr 24, 2013 08:13 AM
coastaljag98
Oct 30, 2012 04:36 PM
