Lights Problem
Old Jan 22, 2025 | 08:57 AM
ianro's Avatar
Default Lights Problem
My old lady has strange fault. When selecting lights side, head and main beam all the panel lights are extinguished, switching off all lights panel lights come back on. Tried all usual checks(as far as I can twist my 86 year old body!) I have not had success, I suspect fault may lie with steering column wiring, such as a shorting out Any clues would be helpful
Old Jan 22, 2025 | 09:22 AM
Cafcpete's Avatar
Stupid question, is your dimmer switch turned off………
Old Jan 22, 2025 | 10:01 AM
ianro's Avatar
Dimmer does not respond to lights off or on
Old Jan 22, 2025 | 11:50 AM
Jhartz's Avatar
Sounds like a short in the multifunction switch: easiest fix is to buy a new one or a used one on eBay. Finding the bad connection and resoldering it takes five hands (none with arthritis). Any good independent specialist should be able to pull the steering wheel and install a replacement (or find the fault and fix the old one).
Assuming all fuses are good.
Old Jan 22, 2025 | 12:38 PM
mayhem's Avatar
Curious, is it all interior illumination or just the gauge cluster? My car has an intermittent issue with the gauges only going full dim at night, independent of the dimmer switch and then they'll come back to full brightness at a time of their choosing and will dim smoothly with the dimmer switch adjustment. The center stack and door controls are not affected at all, they stay full bright and remain dimmer controllable. I'm guessing its the cluster itself, which I need to replace anyway due to a bad LCD screen.
Old Jan 22, 2025 | 12:41 PM
Parker 7's Avatar
I have not done one but is the stalk switch the same as on the X300 as have wire ends soldered ( wires come loose and float around ) to the stalk contacts or small terminal screws ?
I recall pics of disconnected wires on a X300
Good point of having fingers to get in there for reconnecting
See page 55
X300 98/E COVER
Old Jan 23, 2025 | 04:24 AM
ianro's Avatar
Thankyou ALL for your helpful replies and an especial one to cafcpete for his prompt reply for which I am grateful and opologise for not thanking him earlier(THE BOSS called!)
I will try all of your sugestions in due course and report that all cabin lights work as normal so on to the next check and I will let you know when weather allows old bones to function
I had in mind to get into the guts of the steering wheel electicals as this seems to be the next area to clear Will advise in due course and thanks to all thanks again
Old Jan 23, 2025 | 10:22 AM
Jhartz's Avatar
Bunches off threads on the multifunction switch; also on removing the steering wheel to get at the switch. Be especially accurate on reinstalling the wheel so it is aliigned correctly. You will also need an electrical diagram for matching wires to solder points.
Old Jan 23, 2025 | 09:48 PM
Parker 7's Avatar
How to remove/check indicator stalk - Jaguar Forums - Jaguar Enthusiasts Forum
annamiata
Dec 8, 2019 02:56 PM
Austone
Sep 20, 2019 08:00 AM
charger12
Apr 4, 2012 04:23 PM
rowanremote
Audio/Visual Electronics
May 26, 2007 11:05 AM
