Locked my keys in the trunk - UPDATE
Old Aug 18, 2016 | 10:16 AM
KidRock'n's Avatar
Default Locked my keys in the trunk - UPDATE
Okay so my nightmare with the '99 VDP continues. Last night I locked my master key in the trunk. Have a valet key somewhere but no idea where it might be. This morning I was able to get into the cabin with 2 slim jims and an air pump, opened the driver's door handle and accessed the cabin. The alarm luckily timed itself out but I yanked the horn relay and cut the alarm power wire just in case, so as not to disturb my neighbours.
Now, I'm still trying to figure out how to access the trunk. I'm trying to find wiring diagrams for the trunk release switch (which is now inoperative because of the alarm going off) and hot wiring it in order to pop the trunk.
HOWEVER, even if I get the trunk open and get my keys out, I'm worried that the car will still think it's in lockdown mode and will refuse to start even with the master key. Then I imagine that will involve having it towed to the dealer and having them scan the car to tell it that it's not being stolen, and off I go again. Am I following along correctly here?
PS - If anyone has a wiring diagram of the trunk release switch for a '99 VDP or can link me to the appropriate PDF, it would be greatly appreciated.
PPS - The XJR-100 is still for sale and running like a dream!
Old Aug 18, 2016 | 10:28 AM
peeterak's Avatar
I hade similar problem- car was in valet mode. Take off the number plate. Under that is two holes. You must move the lock to right side and boot will be open.Then You get your key.
Old Aug 18, 2016 | 10:48 AM
KidRock'n's Avatar
The only holes behind my license plate are for the license plate mounting screws. I tried sticking a screwdriver into them and feeling around for the lock rod but no luck. I did have luck with this technique on an older XJ though. Back to the drawing board for now.
Anyone know if this thing will still be in lockdown mode when I go to start it back up again?
Old Aug 19, 2016 | 02:53 PM
KidRock'n's Avatar
This link saved me:
X300 Emergency boot (trunk) access ~ Jaguar Vanden Plas "The cats meow"
Drilled a hole, stuck a screwdriver in, popped the trunk and got the keys out. She fired right up after disarming with the key fob. Mission accomplished. Back on the road for another day.
Old Aug 19, 2016 | 11:59 PM
Johnny_B's Avatar
Glad to hear it Now for my suggestion.. Your first stop should be to a Jag dealer to get a spare key made
springer
May 4, 2016 01:51 PM
byjosh
Apr 5, 2016 08:05 AM
TexMurphy
Apr 1, 2016 01:30 PM
XXCalibar
Mar 29, 2016 05:20 PM
