loose connector
Old Jun 8, 2016 | 03:37 PM
bob112's Avatar
Default loose connector
hello im new to this forum and a bit nervous in case i am doing things wrong .
i have a connector hanging down by the oil filter.looks like three pins inside a casing. its not that long a wire as to touch the floor.
i don't know where it connects.
2000 X308 3.2 (added by GGG)
Old Jun 8, 2016 | 04:28 PM
JagV8's Avatar
You need to find the forum for your car and then when you post be sure to put the car details in.
Old Jun 8, 2016 | 05:17 PM
Originally Posted by bob112
hello im new to this forum and a bit nervous in case i am doing things wrong . ......
Welcome to the forum Bob,
Your profile shows "Jaguar X300 yr 2000". The X300 is the 6 cylinder model which was produced from 1995 to 1997. After that came the X308 - the V8 model produced from 1997 to 2003.
Confirm which model you have and I'll move your question to the appropriate forum.
Old Jun 9, 2016 | 03:22 PM
bob112's Avatar
Sorry its a 3.2 v8 automatic
Old Jun 9, 2016 | 06:12 PM
Thanks Bob,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jun 11, 2016 | 07:30 AM
xjay8's Avatar
Welcome to this forum Bob ;o)
We all started somewhere, so don't be bashful about coming forward with ideas and problems to be solved....that's what this is all about ;o)
In your case, it sounds like it could be the connector for the oil pressure sender which is next to the oil filter assembly.
To my knowledge there is no other device in the general area where the cable would be long enough.
You obviously have no warnings come up....because the alternator is also there on that side....check the back of it to make sure all is clean and connected....use a bright digital torch.
Old Jun 11, 2016 | 06:54 PM
ericjansen's Avatar
A picture will help us to advise further.
Old Jun 12, 2016 | 11:48 AM
bob112's Avatar
thanks xj8 most helpfull.
car is having new water pump fitted at the moment,barings are going.i will refit after
Old Jun 12, 2016 | 01:53 PM
Daim's Avatar
Probably an unused VVT plug... Check if you have one the other side...
Old Jun 13, 2016 | 04:11 AM
xjay8's Avatar
Could be wrong but I thought the 3.2 and 4.0 litre engines use different
engine harnesses?
Old Jun 14, 2016 | 05:11 AM
Daim's Avatar
engine harnesses?
Nope. The VVT plugs dangle at the front. They should be strapped to the heads but most of the times just dangle around...
adenshillito
Mar 6, 2021 09:10 PM
99Gsp
Oct 5, 2016 10:23 AM
SinF
May 19, 2016 05:44 PM
jomo
May 14, 2016 08:33 PM
alynmurray
May 11, 2016 08:53 PM
