Loose gaiter on front shock?
Old Nov 3, 2014 | 08:30 PM
Vector's Avatar
Default Loose gaiter on front shock?
The gaiter has come loose on my right front shock, it is item #10 in the diagram below.
It simply slides up and down the outside of the shock. It is supposed to be held at the top by something.
I recently replaced the upper shock bushings. Could I have knocked it loose?
What holds this part in place and can it be reconnected or do I have to replace it?
Vector
Attached Thumbnails Loose gaiter on front shock?-xjx308frontsuspensionroadspringanddampershock.jpg   Loose gaiter on front shock?-xjx308listfrontsuspensionroadspringanddampershock.jpg
Old Nov 3, 2014 | 10:21 PM
Jhartz's Avatar
Nothing to worry about. Try shoving it up into the upper mount.
Old Nov 4, 2014 | 04:43 AM
rocklandjag's Avatar
A little bit of adhesive or silicone caulk between the outer edge of the gaiter and the upper mount will hold it from slipping down
aholbro1
Dec 29, 2024 06:46 PM
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
KarimPA
Sep 12, 2015 08:15 AM
Tar
Sep 6, 2015 11:24 AM
