Lost keys can I use done car?
Old Aug 23, 2018 | 01:54 PM
ls1swap's Avatar
Default Lost keys can I use doner car?
No keys to 2001 vdo xj8 can I just buy a non running car and swap the computer and ignition, or is there anyway to bypass the chip key?
Old Aug 23, 2018 | 02:08 PM
Highhorse's Avatar
For the cost of that, you could have the dealer make you a set using your VIN....and no, you can't bypass it.
Old Aug 23, 2018 | 03:23 PM
avern1's Avatar
Having a key made by the dealer using a VIN is he first step in the process. Because of the year, the key is chipped and will have to be programmed to the vehicle thru the SCLM (security control and locking module). Which would require the vehicle present at the dealer for programming. The are a number of reputable lock companies that can produce a key and program it in your driveway. Try a google search for your area.
Now as far as a donor car, even if you swap out the ignition switch, all door, trunk and glove box locks the key would still have to be programmed for the SCLM to accept it. The SCLM is the module that tells the engine it can crank over. Swapping the donor to your car would give you a wrong part installed and you would have to have the donor SCLM programmed to the CAN bus so it can communicate with the other modules.
mike mitchell
Dec 30, 2020 09:34 AM
entwistlecymru
Dec 22, 2012 10:47 AM
jagmark
May 15, 2012 10:32 AM
Bruce in North Dakota
Feb 15, 2012 10:36 AM
New2Jag
Sep 13, 2011 09:33 AM
