Low coolant light after flush/water pump install
Old Apr 10, 2014 | 06:03 PM
mcm97's Avatar
Default Low coolant light after flush/water pump install
Gents
I got my car back Tuesday from getting the new water pump installed along with upper/lower rad hoses and heater hose. Its driven great so far but this morning as I pulled into the garage at work the low coolant light lit up my dash for about 20-30 seconds and then went out. Nothing appeared to be leaking so could this be a bubble just making its way through the system? Anything to worry about or check later tonight?
Old Apr 10, 2014 | 07:03 PM
RJ237's Avatar
I have found it necessary to top off the tank a time or two after refilling the system.
Old Apr 10, 2014 | 07:07 PM
bigcat777's Avatar
Ditto RJ237. Just add a bit of distilled water to bring it up. No worries.
Old Apr 10, 2014 | 08:22 PM
King Charles's Avatar
Yes I had the same issue after a coolant flush as well I just hit it with 50/50.
Old Apr 10, 2014 | 10:49 PM
jimlombardi's Avatar
You need to fill the coolant expansion tank all the way up to the very top - sensor float inside the tank is very picky - also float sensor get stuck sometimes and needs to have the coolant stirred to free so it floats properly.
Jim Lombardi
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
Sprayall
Sep 3, 2015 07:49 PM
