Lower ball joint repair estimate
Old Jan 11, 2011 | 12:14 PM
theusualsuspect's Avatar
Default Lower ball joint repair estimate
Hey all,
Looking to see what is a fair labor price for repairing one lower ball joint. I have the ball joint already..got it for 50 on ebay and was quoted 2 hours. Just wondering if that is fair as I paid 1 hour labor from a jag dealer a year ago to do the upper ball joint on the other side and to me it looks like the upper would be harder to get to. I definitely could be wrong though. Thanks for the advice!
Old Jan 11, 2011 | 05:18 PM
sparkenzap's Avatar
Two hours would be about right from my exp experience. The upper could probably be changed without removing the spring, and is certainly easier to press out. Are you changing just the joint, or do yu have the entire member?
Old Jan 12, 2011 | 02:06 PM
Just changing the joint. Control arm was already replaced according to some receipts I have so I decided to go with just the joint.
Old Jan 12, 2011 | 02:45 PM
sparkenzap's Avatar
Well, As I recall, pressing the lower joint from the wishbone was an exciting event... It involved grinding an edge and making a toll and then pressing very hard. I think you can find some step by steps in the archives, but it seems right that the lower would be more trouble than the upper, especially if the press operation was included.
Old Jan 13, 2011 | 01:30 PM
Dan R's Avatar
I want to do the upper and lower ball joints soon and have been reading up on it.
I haven't heard of "making a toll". What does it involve?
Thanks, dan
Old Jan 13, 2011 | 01:35 PM
Boomer from Boston's Avatar
I think maybe he meant "making a tool" and it was a typo.
Old Jan 13, 2011 | 07:14 PM
sparkenzap's Avatar
tool!
Thanks Boomer.
Old Jan 13, 2011 | 08:04 PM
Dan R's Avatar
tool!
Thanks Boomer.
Ross,
Is the tool a section of steel pipe with a cut out used in pressing in the new ball joint?
I bought a pipe nipple from the hardware store which seems the right size. I plan to grind off the cut off.
Thanks again,
Dan
Old Jan 14, 2011 | 02:41 AM
sparkenzap's Avatar
Dan:
Yes- As I recall, I used either a 2" or 2 1/2" steel pipe coupling, that I squared the edge and cut the threads out of on a lathe. The threads could probably been cut out just fine with a small grinder "point" on a drill.
Old Jan 14, 2011 | 11:23 AM
Could a regular or long socket of the right outer diameter be used for this?
Old Jan 14, 2011 | 02:03 PM
sparkenzap's Avatar
As I remember (and again I am getting old and senile) the "tool" had to fit over the joint, and the wall thickness was important in order to fit the edge that you need to push on. On the other hand, I probably did not have a 2 1/2 inch deepwell socket.
Old Jan 15, 2011 | 11:13 PM
Dan R's Avatar
As far as I understand, this piece has to have a cut out to clear part of the lower control arm. A long reach socket would not sit flush unless you took a grinder to it. I would imagine socket steel is harder to grind off than pipe fitting steel?
Old Jan 16, 2011 | 10:36 AM
sparkenzap's Avatar
I would say socket steel is not particularly harder (if any) than pipe steel to grind. Sockets are harder to clean up inside to slip over the joint, and, more importantly socket steel is much more expensive than pipe steel.
aholbro1
Dec 29, 2024 06:46 PM
Dan
Sep 17, 2015 05:54 PM
1LowCat
Sep 14, 2015 07:51 PM
JagLove86
Sep 6, 2015 10:36 PM
edtexas
Sep 5, 2015 10:49 AM
