luggage lights
Old Dec 17, 2014 | 01:09 PM
edwood's Avatar
Default luggage lights
I have power, bought 2 new bulbs, nether one works, tried Head lights on,car running-no luggage lights. Anyone have any ideas???? Thanks Ed
Old Dec 17, 2014 | 01:26 PM
luc's Avatar
luc
What do you mean by you have "power"?
Power to the bulb socket..... or where and when?
You need both 12V+ and ground so if you have 12v+ to the socket, it has to be ground
Old Dec 17, 2014 | 01:42 PM
edwood's Avatar
When I test the socket with electrical tester, it has power-turns on the test light,which I had grounded. Thanks
Old Dec 17, 2014 | 02:49 PM
Jhartz's Avatar
Assuming you have turned the lights on: then we know the switch works at the boot lock; the fuses are good; the wires are good> Sure you have the right bulbs? Try prying the inner spring of the socket out a bit -- you might not have a good contact.
Old Dec 17, 2014 | 09:14 PM
jimlombardi's Avatar
You might have a faulty micro switch.
These 2 luggage lights turn on when the trunk lid is raised and turn off when it closes.
The micro switch that controls it is mounted on the latch and you have to partially remove the latch to it to get the switch off. part number is LNC6242AC - gaudin jaguar discount price is $58.58 plus shipping (probably $15 more).
Look at this other thread on Luggage lights:
https://www.jaguarforums.com/forum/x...working-38213/
Jim Lombardi
Old Dec 18, 2014 | 10:58 AM
edwood's Avatar
Thank You- It was the micro switch- I have a 2003 xj8 Parts car- swithched them out-luggage lights work. Thank you for your help. Ed Wood
Old Dec 18, 2014 | 08:38 PM
motorcarman's Avatar
I posted an answer for the X100 and realized that this is the X308.
NEVER MIND
bob gauff
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
