Manual gearbox will be next step in power stay tuned
Old Jun 14, 2012 | 10:40 AM
XJR-0220's Avatar
ud
Default Manual gearbox will be next step in power stay tuned
Big thanks to Steve for the link to XKR transmissions I sent them an email and will be converting my XJR into a 5 speed manual. This will be a huge improvement not only with weight, power to the wheels plus the gear ratios are much better. So stay tuned for this fun filled conversion got to see how much and how long to get it all here, hopefully this is all feasible
Old Jun 14, 2012 | 01:32 PM
Sean B's Avatar
it'll work out under 10$k if you use your own gearbox, I'd suggest looking for a lhd XJS manual pedalbox assembly.
My gearbox conversion is a 6 speed.
Old Jun 14, 2012 | 01:35 PM
XJR-0220's Avatar
ud
wow maybe it wont be I havent heard back but didnt think it would be so much more I think I may have to go with your idea holy cow Id rather do the twin screw before tht and have cash left over.
Old Jun 14, 2012 | 08:48 PM
adam699's Avatar
Honestly, as fun as the manual is I think they are overrated. Burned clutches, stripped gears and all the headaches with the conversion so you can grind it 'till you find it just doesn't do it for me 722.6 is a great trans and parts to make it more durable are easy to find if you know where to look.
Go for the twin screw and you'll be chirping tires between shifts anyway. I'm sure there is a way to convert it to a paddle-shift with an MB shifter assembly.
I am however curious as to how they get around the TCM computer with a manual so it doesn't throw codes.
Old Jun 15, 2012 | 12:51 AM
avos's Avatar
They have an ECU that mimics TCM behavior. The TCM is for instance sending out ever 20ms (iirc) a signal that it’s there for instance.
Old Jun 15, 2012 | 07:09 AM
mechelement's Avatar
$10,000 for a manual transmission swap is absurd.
Old Jun 15, 2012 | 11:17 AM
SteveM's Avatar
And you don't even get the most important part for that price - the transmission!
I'm glad I don't want one.
Old Jun 15, 2012 | 01:55 PM
BWAHAHAHA! That thing better shift itself and be able to handle 1000+hp and torque for that coin.
Old Jun 15, 2012 | 02:16 PM
XJR-0220's Avatar
ud
no doubt so yeah mind changed just gunna enjoy my tough merc trans, Have the n ew blue solenoids a d new fluid and fliter Ill be doing when I get back
Old Jun 15, 2012 | 02:18 PM
SteveM's Avatar
The stock auto already does that, and it could probably be built to handle that much power or close to it.
Old Jun 16, 2012 | 05:12 AM
Sean B's Avatar
For those that find it interesting...
video
Article (see XKR side note)
http://www.eapj.com/JWM%20Manual%20XK8%20v2.pdf
discussions
Manual XK8! Driven!
Jaguar World Monthly Forum - Manual gearbox conversion
The reason I'm hunting an XKR...... ZF 6 speed....twin screw....if not, I'll buy an Aston V8 Vantage.
Old Aug 23, 2012 | 10:36 PM
adam699's Avatar
Default Guys with Manual Conversion/ Eliminating the TCM
https://www.jaguarforums.com/forum/x...50/#post568906
Old Sep 29, 2012 | 09:39 PM
knojag's Avatar
A few pix with notes on the manual trans conversion for my track XJS. It cost less than $2000, though no computers were abused in the process.
Facebook
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
AL NZ
Sep 4, 2015 08:39 PM
pnwrs2000
Sep 3, 2015 11:55 AM
