Memory Seat Positions Will Not Work
Old Sep 17, 2012 | 08:26 PM
BigTexx's Avatar
Default Memory Seat Positions Will Not Work
I own a 1998 XJR with 97k miles and have just started messing around with the memory settings for my seats. The steering wheel and mirrors will adjust to the memory settings when I press the buttons/key fab but the the seat itself will not return to the desired position. I did a little searching about the problem but did not find too much information other than there is a black box underneath the seats that may have a broken lead/resistor that I can solder to try and fix the problem. If any of you have had similar problems your input would be very appreciated!
Old Oct 14, 2012 | 12:17 PM
stevepaa's Avatar
I have the same problem. I'll also start looking.
Old Oct 14, 2012 | 10:53 PM
JaguarXJR02's Avatar
mine has always been intermittent since I got the car in 07'
Old Oct 15, 2012 | 08:28 AM
motorcarman's Avatar
I uploaded hundreds of TSB in the large file area.
You need to find 501-35 and 501-51 for diagnosis and repair.
I would suggest replacing ALL the position potentiometers if you do any at all.
It is easier to do them all at once if you disassemble the seat.
When the cars got old enough to be out of factory warranty, customers rarely spent the money to repair the memory function.
The sensors were about $300 EACH and there are 5.
Add labor to that and you can see why people just manually adjust seats.
bob gauff
Old Oct 15, 2012 | 11:21 AM
stevepaa's Avatar
What mine does is this.
It will not take a new memory setting, Just the one that the PO had.
Also if I keep pressing on 1 or 2 it keeps tilting the seat forward until I stop.
Old Dec 6, 2012 | 08:37 PM
BigTexx's Avatar
A new update to this old problem. None of the memory seat positions will move anything, not the steering wheel, mirrors or the seat. I noticed that if I put my finger in the middle of the memory seat position button area (for lack of better terms) it is extremely hot, like will burn my finger if I leave it there. Will be investigating this problem when I get some free time.
Old Dec 7, 2012 | 07:56 AM
As I stated above
"I uploaded hundreds of TSB in the large file area."
Stop typing and read all the TSBs in the uploaded section.
Most of the common issues people have are addressed in TSBs.
bob gauff
Old Oct 22, 2013 | 05:47 AM
kompressed_xj's Avatar
Bob, thanks for uploading all that info. I am new to xjr ownership and my seat memory has no reaction as per the above posts, so am off to read your info, cheers, d
Old Oct 22, 2013 | 01:42 PM
jagjunky's Avatar
good luck with bob's info....i had a similar problem with my drivers seat....but after i did a re-set and than reconnected the battery...i managed to get the seat back to my original custom setting and no i will not even try to re-adjust the seat as i am the only driver.....worth a try...but you may have uncovered something more serious.
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
XFR_Gold
Sep 2, 2015 12:24 PM
