Misfire, swap plugs and coil!
Old Mar 28, 2018 | 03:53 PM
prodigy215's Avatar
Default Misfire, swap plugs and coil!
I have a P1316 and P304 code, i changed all the spark plugs and swap coils out twice. Still shows the same P304 and P1316 code. What else could the issue be? Is it a fuel injector thats bad? Please help thanks
-2003 Jaguar VDP
Old Mar 28, 2018 | 04:29 PM
Highhorse's Avatar
For your 304... have you checked for intake leaks? The common denominator is you have swapped coils and plugs with the same result. It could be a bad injector or injector connector.
For 1316... fouled/worn plug, bad injector, low compression, low fuel pressure, even a bad ECM ...and since you swapped them which kind of eliminates them faulty coil pack
Old Mar 29, 2018 | 02:22 AM
JagV8's Avatar
Could be wiring / connector.
Old Mar 29, 2018 | 07:26 AM
Don B's Avatar
Hi prodigy215,
I am attaching the Diagnostic Trouble Code Summaries manual, which gives possible causes for each code.
Cheers,
Don
stonkeruk
Mar 29, 2012 03:10 AM
jagstr03
May 31, 2011 10:18 AM
bigwiki
Jan 9, 2011 08:40 AM
wnlewis
Apr 2, 2009 10:17 PM
