My Full 3.5" Aluminum Intake. Compared With Mina Gallery 3" Intake.
Old Oct 23, 2024 | 06:53 AM
Hooli's Avatar
I can see his point because it's metal.
If it's actually an issue I've no idea.
Old Oct 23, 2024 | 12:00 PM
Jhartz's Avatar
I think you would need the heat shield (reread #20)
Old Oct 23, 2024 | 09:30 PM
Addicted2boost's Avatar
I would highly recommend siliconeintakes.com for a real carbon fiber tube. You’ll have to make your own intake though. Much less heat than aluminum.
Old Oct 24, 2024 | 03:09 PM
Mvirgil's Avatar
Does not matter.... the thermal transfer from the pipe to the intake charge air will be insignificant. Unless you have massively increased surface are (like your intercoolers), the pipe does not have Signiant surface area compered to the amount of air being sucked through. Charge temps for these cars are pretty high anyway, gen3 Heatons are not kind combined intercoolers are stabilized off your cooling system. an extra PSI of boost will add much charge temp then the aluminum tube.
xjrjag
Feb 8, 2024 04:38 PM
griff831
Nov 29, 2023 10:44 AM
Barry_Tucker
May 13, 2021 11:08 AM
on1r1
Jan 19, 2018 10:57 PM
BigTexx
Jan 30, 2013 12:46 PM
