Need abs module diy repair guide please
Old Oct 31, 2012 | 03:47 PM
theusualsuspect's Avatar
Default Need abs module diy repair guide please
Searched the forums with no luck in finding the abs module removal and repair guide. Wanting to get this last issue fixed so i no longer have any warning lights! Cant even imagine a warning free dash lol! Thanks in advance
Old Oct 31, 2012 | 03:52 PM
RJ237's Avatar
This should give you a start.
JagRepair.com - Jaguar Repair Information Resource
Old Nov 2, 2012 | 06:42 AM
Thanks that def helps! Anyone else with a more in depth guide?
Old Nov 2, 2012 | 07:24 AM
jchavez76's Avatar
I did repair my abs module a year ago. I did not find a guide either. My porblem was bad solder joints for the pump circuit. I wonder if posts of this type are intentionally removed or discouraged due to the potential brake failures due to improper repair.
If a moderator chimes in and gives the go-ahead, I will share what I can remember about my ABS module repair.
Old Nov 2, 2012 | 07:29 AM
plums's Avatar
There are multiple threads on the subject with pictures already.
Old Nov 2, 2012 | 09:07 AM
jchavez76's Avatar
Thanks, Plums. When I get a chance I'm going to look for the threads and determine if I have anything new to add. Back to work for now.
Old Nov 4, 2012 | 10:59 AM
jchavez76's Avatar
Ok. I admit that I'm not the sharpest tool in the shed. However, I've been trying for about an hour to find any post that gives a step by step with photos.
Nothing on this forum at least.
So, theusualsuspect, I found something that should help. If you search the forum we're on now (X308) by clicking the black drop down that says "Search this foum" (above the # of views display at the top right of the screen) and type in "ABS module re-solder", it will get you started. In the search results, look for the one titled "ABS module removal" I think. Post #3 is from "Gus" and has a link to another forum. I tried it and I had to register in order to view the link. It's worth it! Photos and step by step.
The only thing I did that was different from this great post was to use a heat gun to get the cover off of the module. The hack saw trick looks good too. Just sounds bad. It would be nice find that info on this forum. (It may be here, but , I give up trying to find it.)I did learn a great deal while searching so I encourage you to do the same if you haven't already.
Good luck.
Old Aug 30, 2021 | 04:37 PM
oldjaglover's Avatar
Originally Posted by jchavez76
ok. I admit that i'm not the sharpest tool in the shed. However, i've been trying for about an hour to find any post that gives a step by step with photos.
So, theusualsuspect, i found something that should help. If you search the forum we're on now (x308) by clicking the black drop down that says "search this foum" (above the # of views display at the top right of the screen) and type in "abs module re-solder", it will get you started. In the search results, look for the one titled "abs module removal" i think. Post #3 is from "gus" and has a link to another forum. I tried it and i had to register in order to view the link. It's worth it! Photos and step by step.
The only thing i did that was different from this great post was to use a heat gun to get the cover off of the module. The hack saw trick looks good too. Just sounds bad. It would be nice find that info on this forum. (it may be here, but , i give up trying to find it.)i did learn a great deal while searching so i encourage you to do the same if you haven't already.
Good luck.
a "heat gun"?
Old Aug 30, 2021 | 04:55 PM
Jhartz's Avatar
Answering a nine year old thread -- a new record!
Old Aug 31, 2021 | 06:35 PM
I have been a participant on this forum since 2008, and I respond to ANY post of ANY age that refers to one of my posts. So, 9 years.....sure, why not.
Old Sep 1, 2021 | 02:30 PM
pcolapacker's Avatar
Originally Posted by theusualsuspect
SWanting to get this last issue fixed so i no longer have any warning lights! Cant even imagine a warning free dash lol!
Small piece of black electrical tape works.
Old Sep 1, 2021 | 03:41 PM
60Gunner's Avatar
People often have things of value to add and I don't see a problem adding to old threads either. Seems to me to be better than starting new ones and having 15 threads of the same subject matter. But what do I know?
Seems to be an issue that comes up regularly on every forum I've been on.
Old Sep 2, 2021 | 12:37 PM
Talking LOL
K
LOL!
trosty
26
Dec 18, 2022 06:40 PM
skyryder
Mar 25, 2016 08:18 PM
1964Daimler
Oct 3, 2015 12:18 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
