Need step by step guide to changing coolant on 98 VDP
Old Nov 21, 2010 | 04:45 PM
brandon lip's Avatar
Default Need step by step guide to changing coolant on 98 VDP
Hello all, need a step by step guide to changing the coolant on my 98 VDP. Yesterday, the thin plastic tube on top of the engine broke and a lot of the coolant was lost. Just got the car 2 months ago so not too familiar with the car's inner workings. Any help would be much appreciated. Thanks.
Old Nov 22, 2010 | 05:57 PM
jimlombardi's Avatar
Default Coolant change extract from JTIS
Here are the instructions and illustrations from the Jaguar JTIS CD.
I created this PDF file from the extract:
1998 Jaguar Changing Coolant .pdf
Hope it works for you
Jim Lombardi
Last edited by jimlombardi; Jan 17, 2013 at 08:49 PM. Reason: had to change the attachment location
Old Nov 23, 2010 | 12:44 AM
Default thank you, jim
I will give it a try, jim. I took a second look today and realized that the damaged hose was just part of the problem. Some kind of animal (rodent???) got into the engine compartment and chewed up some wires to the passenger side headlight and most likely did the damage to the coolant reservior hose also. I should have figured it out when I saw some engine compartment insulation material all scratched up and scattered around. Those damn rodents. Anybody with advice on how to keep animals from crawling into your engine compartment and causing havoc??? I have only heard of such problems from others and I guess I am now one to experience it too!
Old Dec 16, 2010 | 03:36 PM
mzs_biteme's Avatar
Quick way: take the clamp off of the upper radiator house going into the distribution pipe, and pull it up a bit. Fill until you see the coolant half-way in the house. Reattach the house, and top off using using the "header tank". Takes less than 5min.
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
jimmiejag
Sep 9, 2015 02:56 PM
KarimPA
Sep 3, 2015 07:32 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
