New member xj8 flooding problem
Old Nov 3, 2010 | 07:33 PM
ShaneIam's Avatar
Don't shut it off until it's hot. I've had this happen once and it was because I drove only 20' from the driveway into the garage. And I was able to get it started by cranking the ignition and rapidly pumping the gas pedal...
Old Nov 4, 2010 | 11:06 AM
Jaguar kid's Avatar
I had the same thing happen to me, I was claying the car in the garage and had to move it 3ft the engine was on about 20 seconds, after I had finished my nice work on the car, wanted to move it out the garage, and of course it would not start, flooded, so I held the accelerator to the floor and turned it over till it started about 30 seconds and it fired up, I quickly leaned that these engine don't like being switched on and off to quickly, especially when cold.
Old Oct 17, 2014 | 11:37 AM
Ccharlie1's Avatar
I had a (somewhat) similar problem with my "06 XK-8, and the shop is STILL trying to find the reason and the cure!
Old Oct 19, 2014 | 10:28 AM
Jhartz's Avatar
But the correct approach to overcoming a flooded 308 is to hold the pedal all the way to the stop and crank it until it cleans out and starts. Don't crank it for more than a few seconds each time, the starter will heat up if you crank too long.
But maybe a can of SEAFOAM and a cleaning of the bore and throttle might preclude a problem in the future. How old are the plugs?
Old Oct 20, 2014 | 04:33 AM
Ccharlie1's Avatar
Tried all of the above. Now they think it's the fuel pressure regulator.
Old Oct 21, 2014 | 02:33 PM
Ccharlie1's Avatar
NEW fuel pressure reg seems to have fixed the flooding (couldn't FIX the reg?), but now there's a strange ticking sound (from engine)?
Old Aug 6, 2017 | 06:52 PM
holybananas's Avatar
Do you know where the regulator is?
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
obwoodie
Sep 3, 2015 07:45 PM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
