New Rear Badges
Old Mar 10, 2013 | 07:03 PM
JaguarXJR02's Avatar
Default New Rear Badges
Found new rear badges for my XJR on ebay. They arrived quickly and I fitted them. my process was basically to pry them off a bit and then pull fishing line back and forth behind them until the badge was separated. after some glue remover the new ones stuck right on.
Old Jaguar badge:
Old XJR Badge:
Surfaces prepared:
New Jaguar Badge:
New XJR Badge:
Attached Thumbnails New Rear Badges-f46c2b95-fb5c-40ee-a9f5-75a4ef051511-22254-0000092c216b6c2f_zpsc145d53c.jpg   New Rear Badges-7e63e0b5-4f2c-4789-ab01-14059ff94bce-22254-0000092c3a844b15_zps3f951f2e.jpg   New Rear Badges-195042c5-94a8-4ec0-8cf3-dc3efe41b875-22254-0000092c52062652_zps3d67790d.jpg   New Rear Badges-b7522c8e-7c2c-4bd7-bc25-54f73ae04a72-22254-0000092c70bf03c3_zpsfabae8ad.jpg   New Rear Badges-278847ab-725c-4f56-8a48-b71c26275c9a-22254-0000092c7b39512e_zps54eccb6b.jpg
New Rear Badges-482a0c93-5ec8-4d58-b292-6a7641a0d717-22254-0000092c65a34398_zps2e2d42bc.jpg
Old Mar 10, 2013 | 07:57 PM
OldMike's Avatar
Very nice!
Old Mar 11, 2013 | 08:02 AM
Chris Roxie Lewis's Avatar
Looks great. Shiny things always do.
Old May 25, 2014 | 08:55 PM
bigcat777's Avatar
Very nice work.
Old May 26, 2014 | 07:03 AM
Badbenz94's Avatar
What a huge improvement!! No need for a heat gun?
Chris
Old May 28, 2014 | 04:15 PM
xjrmageddon's Avatar
I need to do this... My badges are looking quite sad and sun rotted.
Speaking of which, my little side badges are having issues too (the leaping jaguars on the front fenders). Maybe I'll just refresh them all... Wonder what those side jaguars are called. I'll have to do some digging. A cursory check of ebay only shows the keyhole XJR badge, no JAGUAR badge in the right color, and no fender jags in good shape. I'll have to keep peeking I guess.
Wonder if there's any way to refresh the existing badges. The coating is quite pitted.
Old May 29, 2014 | 09:08 AM
ragman1171's Avatar
I have purchased a set for my VDP as well, but I am unsure as to the proper procedure for removing the current badges. I have considered warming them up with a hair dryer or heat gun (VERY carefully with the latter of the two) and then using fishing line to get under the badges. Will you please pass on how you accomplished that task? Thanks!!!
Old May 29, 2014 | 09:50 AM
Badbenz94's Avatar
I am changing my right side XJR badge now, I just got a screwdriver into the key hole area and pried it back slowly. If you look at the new badge, this is not going to hurt anything. My came off without heat, just needed a little work to remove the old adhesive.
The left side I would guess a heat gun and get a plastic scrapper or something non metal to remove.
Chris
Old May 31, 2014 | 08:46 AM
I used a plastic putty knife to pry them back some, then fishing line to slice them off. Then used the plastic putty knife carefully to scrape most of the glue crap off. Then used bug and tar remover to get back to factory clean before sticking on the new ones.
good luck
for ebay searches "fender badge" or "fender emblem" works well
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Quantico
Oct 13, 2015 10:34 PM
AtholC
Sep 9, 2015 09:07 PM
davidladewig
Sep 3, 2015 06:32 PM
