No high beams
Subscribe
Jul 23, 2022 | 09:57 AM
Hi all is there a relay for the high beams, lows work fine. Thanks.
Reply 0
Jul 24, 2022 | 06:37 PM
It's in the front fuse/ relay box under the hood/ bonnet. The larger of the two boxes. It's called the "DIP" replay: its #5. Have someone flick on the high beam and you should hear; or you can feel the relay clicking if you put your finger on it. You can try swapping one from another position to see if that fixes the problem....
Reply 1
Jul 25, 2022 | 12:10 PM
Might also be a broken wire/solder connection in the multifunction switch.
Reply 0
Subscribe
Currently Active Users (1)
