No Turn signal noise/reverse sensor sound
Old Jul 1, 2012 | 07:03 PM
marksdresser's Avatar
Default No Turn signal noise/reverse sensor sound
I have nor turn signal "noise", "Gong","click" and I also have no backup sensor sound. Also when I select memeory and then select a 1 2 or 3 I get no report back yet it does program the seat and mirror settings. Any thoughts? Oddly enough about once every 6 onths or so all will be working fine. Perplexing. Thanks to everyone here in the forum, I have saved no ess than 5 k with everyones advice and experience! Katherine is loving the attention.
Old Jul 1, 2012 | 07:27 PM
plums's Avatar
Those sounds come from a speaker on the right side of the steering column. It sounds like the wiring may have gone intermittent.
Old Jul 2, 2012 | 10:36 AM
SuperSport's Avatar
I just had this happen. I think it's the wiring as mine is also intermittent. I believe it changes due to my Automatic Steering wheel adjustment every time I get in and out. Also likely the reason for the break in the first place. I'll be getting into it in the next few days.
Old Jul 3, 2012 | 02:04 AM
Distraxi's Avatar
Is the backup sensor sound from the same speaker as indicators etc? I have no indicator sounds or other bings & bongs, but do have proximity sound effects. I was going to yank the speaker, but if they're through the same speaker that ain't my problem.
Old Jul 3, 2012 | 05:10 AM
jimlombardi's Avatar
This is the weblink to the "Turn signal" thread (it has info on replacing the speaker in the steering wheel colmn):
https://www.jaguarforums.com/forum/x...-signal-53522/
Here are two other thread on this subject:
https://www.jaguarforums.com/forum/x...e-quiet-28773/
https://www.jaguarforums.com/forum/x...-alarms-49600/
post 10 has replacement speaker source information
I created these 2 JPEG files from the JEPC (Jaguar Electronic Parts Catalog):
Audiable Warning Speaker (part# LXF2280AA - Retail $29.50 Discounted $23.96 - Europe 23,49 euros):
Reversing Aid Speaker (to Vin# F00034 - Part # C2N2421 supercedes XR88580 - US Retail $43.15 Discounted $35.05 and Europe price $26.06 pounds; from Vin F00035 - C2N2421 supercedes LNF7351AA):
I also found description of the Parking Aid Sounder location in one of the Electrical Diagram PDF file - quote "Center Rear Headlining".
Jim Lombardi
Old May 20, 2016 | 01:26 PM
King Charles's Avatar
About to check my wiring in my wheel this weekend, good info. here.
RoyLittle0
May 25, 2023 02:38 AM
mbergen
Oct 23, 2019 10:26 PM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
