is this normal ?
Old Apr 29, 2012 | 04:41 PM
jameson's Avatar
Default is this normal ?
03 xjr
Hit 250 km/ h today or 155mph and the yellow light and check engine light started flashing. Message was restricted performance.
No response to gas pedal until the car slowed down to about 120 km/h or 70 mph.
Then everything resumed to normal....
I am assuming this is the speed limiter ?
Old Apr 29, 2012 | 04:56 PM
Stu 1986's Avatar
I don't think it is normal, as I have cruised for several miles at the top speed. The limiter just holds it there, it doesn't slow it down. Get the codes read and see what you get.
Old Apr 29, 2012 | 09:40 PM
jameson's Avatar
Will I pull a code even if the check engine light is no longer on ?
should I try again to see what happens ?
Old Apr 30, 2012 | 12:51 AM
avos's Avatar
The speed limiter blocks you from going faster (very subtly), so you had an issue, better to read the codes soon, it should be still there.
Old Apr 30, 2012 | 09:13 AM
jameson's Avatar
ok,
pulled the codes p0303 p0308 p1313 p1314 p1111
any thoughts ?
Old Apr 30, 2012 | 01:06 PM
Stu 1986's Avatar
Use the search tool on the toolbar and see what it gives you Also check the FAQ section as I think there is something there regarding codes.
Old May 5, 2012 | 06:42 PM
jameson's Avatar
Thanks stu !
I know for sure I have an issue now as I took it for a spin again and at 130 MPH it did the same thing....
Will research codes...hopefully nothing too bad ...
Old May 5, 2012 | 06:55 PM
OldMike's Avatar
Holy mother of god -- please tell me where you guys are driving that fast so I can stay out of your way! LOL
Old May 5, 2012 | 07:05 PM
jameson's Avatar
ok... so again no symptoms until speed of 130 mph is hit...( even with rpms at redline at lower speed nothing feels wrong)
p0303-misfire cylinder 3
p0308-misfire cylinder 8
p1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
soo I have a misfire on cylinder 3 and 8 but why does this only happen at 130 mph or higher ?
p1313 and 1314 related to p0303 and p0308? I would assume so ?
and p1111 is IAT sensor high voltage...again im confused as to why it would only happen at high speend only????
So where should I start guys ? Replace spark plugs ? replace ignition coils ??
Let me know where you guys would start ...
Thanks in advance !
Old May 5, 2012 | 07:30 PM
JaguarXJR02's Avatar
it's very strange that it only happens at high speed. maybe it has something to do with airflow forcing something into some wiring. like the plastic under the front bumper coming up and touching a wire or something. Just a random guess.
as far as the misfires, what I do on other cars when I start having that issue is to move the coils around. drive for a while and then see where you get codes for. that way you can determine if the ignition coil is the issue or if it is something else
good luck
Old May 6, 2012 | 12:16 PM
Sean B's Avatar
Well it's time to take the cam covers off, coil's acting up can be a bad boot connection to the plug. Have a look at the plugs also, do you know how old they are?
As suggested, swapping the 'bad' coils to other cylinders will confirm if they're dying.
The P1111 is a 'nothing to worry about' code.
The 1313 has a check spark plug gap/fouled/failure, and it's rather dramatic title of cat damage would only be if driven for a long period while the fault is there. And it's flagged by a misfire so related to the dodgy coil or plug, or plug boot connection.
Hope this helps, let us know how you get on, and make sure the engine's in tip top shape for the high speed runs, i.e. a full service, oil, plugs and filters. (I'd suggest the best stuff you can get, not cheap shat)
Old May 6, 2012 | 07:08 PM
jameson's Avatar
Another weird thing...pulled to codes and they arent for the same cylinders as for the first time this happened....weird !!! i still get misfire codes but for different cylinders....
Will put new plugs and take for a spin and report back to you guys....
workworkwork
Oct 23, 2015 10:26 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
redxk8
Oct 4, 2015 08:28 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
