OBD II Codes - Jaguar specific codes above 1000
Old Aug 1, 2018 | 12:43 PM
XJR Pilot's Avatar
Default OBD II Codes - Jaguar specific codes above 1000
Hi All,
Not sure if this has been posted, but if you put your OBD scanner into your Jag and got P numbers above 1000, those are manufacturer specific codes. You will never find in a book. However, I found a site that shows all the Jaguar manufacturer codes. See link to codes, and if you print out, it is 16 pages!
https://www.icarsoft.com/Article/s-104-104.html
Old Aug 1, 2018 | 02:21 PM
motorcarman's Avatar
I worked at a Jaguar dealer for years and years. I have all the DTC guides up to about 2005.
What do you need??
bob
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 1, 2018 | 05:30 PM
JagV8's Avatar
Originally Posted by XJR Pilot
Hi All,
Sadly some (maybe a lot) of those are wrong!
Use the ones on this site / what Bob posted.
Old Aug 10, 2019 | 11:01 PM
mj1903's Avatar
Sorry, scrolled to the bottom and posted on the "related thread" by accident, please ignore.
sanmigmike
XJ XJ12 ( X305 )
May 28, 2015 09:36 AM
califjag
Apr 17, 2014 02:34 PM
Yaguareté
Nov 1, 2013 05:55 PM
patrickw813
Mar 3, 2010 08:11 PM
BugDoc
Aug 5, 2009 02:58 AM
