Oil Change
Old Oct 10, 2018 | 03:55 PM
JagJoe80's Avatar
Default Oil Change
I am carrying out a full service on my car , oil and filter, fuel filter, spark plugs and air filter. Should I flush the engine out or just drain and fill with new oil and filter.
I am being told two different pieces of advice, one to flush the other not to flush.
Would appreciate advice please.
Many thanks
Joseph
Old Oct 10, 2018 | 04:43 PM
Carnival Kid's Avatar
Personally I wouldn't do an engine flush. I would assume the car has had regular oil changes during its life, if not during its later life, I would think it certainly would during its early life, and regardless, with modern detergent oils there is little/no sludge left in the engine as there used to be in the pre-detergent oil days.
If you feel you want to be "conscientious", what I would do is perform a "double oil change", I would change the oil and filter, and then 500miles later I would repeat the oil and filter change. And if you want to be triple sure, change it again in another 500-1,000 miles, before returning to a normal schedule.
Old Oct 10, 2018 | 04:54 PM
JagJoe80's Avatar
carnival Kid
Thank you very much for your advice.
Will get back to you with the outcome.
Joseph
Blue XK
Mar 20, 2012 09:22 PM
christer200
Apr 7, 2009 11:44 PM
leodog
Jan 4, 2008 06:48 PM
Humy
Jul 19, 2007 12:52 AM
