Oil Cooler Removal
Old Apr 19, 2025 | 04:55 PM
  #41
mayhem's Avatar
I have the full replacement EOC on my car from Nialinium's car, so if all you need is the nut to get yours sorted, let me know. I have all my original parts, minus the rubber hoses on the inlet side. The exit hose, the nut is cracked, but the inlet nut is fine...at least I think its the inlet.
Old Apr 19, 2025 | 05:09 PM
  #42
Addicted2boost's Avatar
Thanks, I really appreciate your offer. I’ll take it into consideration if I can’t find a suitable replacement.
https://www.mishimoto.com/universal-tube-and-fin-crossflow-oil-cooler.html?sku=MMOC-TF589-N&utm_source=bing&utm_medium=cpc&utm_campaign=(C)% 20Smart%20Shopping%20-%20Best%20Categories&utm_term=2332476479918704&utm _content=Ad%20group%20%231
Old Apr 19, 2025 | 05:12 PM
  #43
mayhem's Avatar
Cool find. Looks like about the right length.
Old Apr 19, 2025 | 06:23 PM
  #44
Silverjag0's Avatar
Check this cooler and for the hoses get transmission hose and cut the thread if it's bad use fuel clamps the regular clamps will cause leak because doesn't tight it circularly but like egg shape which cause leaks , find correct thread aluminum barb hose adapter size it's easy but you need to get the correct parts and having patience
Old Apr 19, 2025 | 09:55 PM
  #45
Nice find! Thank you!
I will say that I’m a bit concerned about the core depth of .71” being a little anemic. I know that somewhere is an oil flow diagram of the S/C engine with the oil thermostat and cooler. I just want to make sure there’s no starvation upon re-entering the engine.
Old May 2, 2025 | 07:43 AM
  #46
mayhem's Avatar
@Addicted2boost , just tried to reply to your message, but it says you've exceeded your storage for message, so you need to delete some stuff in your inbox or maybe sent items.
EcbJag
Sep 22, 2022 08:56 PM
Shahar Alon
Jul 2, 2019 03:23 AM
orangeblossom
Jul 10, 2015 09:40 AM
RagJag
Jun 19, 2015 07:51 AM
raphell
Aug 16, 2012 09:25 AM
