Oil Leak from top of engine
Old Mar 8, 2012 | 12:57 PM
rsamples's Avatar
Default Oil Leak from top of engine
I have oil residue around the oil cap, the crankcase vent hose, and the little sensor next to it. (Sorry, don't know the proper names on a Jag.) Oil is backing up into the air intake housing, and I'm adding a about a quart every 2000 miles. Does anyone have an idea of what to do about this? It seems pressure is coming from somewhere and pushing the oil out of these places, but not sure where to start looking. Thanks
2000 xj8 95k
Old Mar 8, 2012 | 01:18 PM
Brutal's Avatar
Your part load breather on the drivers side is plugged up. Carefully undo the part laod breather hose connector and with a 1/8"drill bit by hand clean out the oriface in the cam cover opening. There are threads and pics around here somewhere of it
Old Mar 9, 2012 | 12:24 AM
Estilian's Avatar
Check out this thread: https://www.jaguarforums.com/forum/x...r-filter-9655/
On the first page you'll find a reply from me with pictures about how to clean part load breather.
Old Mar 9, 2012 | 06:51 AM
xjay8's Avatar
Hello Brutal,
The size you have given to clean the Part Load breather is too large and will affect slow running.
The correct size is 2.5mm or 0.09843"
PART-LOAD BREATHER CLEANING Photo Gallery by Max Heazlewood at pbase.com
Cheers,
Maximus
Old Mar 9, 2012 | 07:01 AM
xjay8's Avatar
2000 xj8 95k
Rsamples, how many miles has your car coverd?
Apart from the points already mentioned, you may be well advised to have a 'blow by' test performed on your engine.
I say this because adding a quart every 2000 miles is far from normal with these engines.
What sort of service records are with this car?
How often is the oil and filter changed?
Cheers,
Maximus
BrentGardner
29
Dec 16, 2024 12:13 AM
Torrid
Feb 15, 2020 08:03 AM
rusty37
Jun 7, 2016 04:43 PM
niner nellie
Sep 1, 2015 10:53 PM
peterg19
Aug 28, 2015 08:42 AM
