Oil seepage
Old Mar 1, 2012 | 11:22 AM
blackwolf560's Avatar
Default Oil seepage
I have a very small oil seepage around a part I'm not familiar with. I'll try to decribe it the best way that I can while I try to get pics.
It's on the driver side engine bay. You can get to it without removing anything. It looks like a sensor that plugs into the valve cover area at the front top of the engine what appears to be the timing area. On a BMW or Mercedes (w140) I would call it a referance sensor. The 1988 BMW has one that looks similar to it but smaller located near the crankshaft front gear.). But on the Jag, if it is a reference sensor, looks like it measuring timing. Based off this anyone can tell me what it is so I can order the small gasket for it? If not, that's ok. I'll try to find some pics of it in the mean time. I dont own a camera and any pics off my phone must be routed to GA to a relative who must then post the pics online for me. (I know, I live in the stone age.)
Thus it might take a few days for pics from either going out to bu ya cheap camera, (two days to figure out how to use the blasted thing.) and then a day to figure out how to get it on my cpu. or doing the other way.
Old Mar 1, 2012 | 11:26 AM
found a pic to help out.
See the plugged in wires next (left) to the engine oil dipstick? What is that part? I need the gasket for it.
Old Mar 2, 2012 | 01:12 AM
plums's Avatar
VVT actuator or related.
Old Mar 2, 2012 | 04:45 AM
Sean B's Avatar
and you need the seal part number AJ82856
Old Mar 2, 2012 | 12:49 PM
orca99usa's Avatar
Plums nailed it. It's the variable valve timing actuator. Sometimes the seals fail and need to be replaced.
Old Mar 3, 2012 | 07:02 PM
alright then. what do I need to do to remove it, and replace it?
Old Mar 6, 2012 | 04:34 AM
Sean B's Avatar
coil pack covers, coils then the cam covers.
Old May 9, 2024 | 10:12 AM
jimlombardi's Avatar
I need to replace both vvt seals that are leaking. I have the parts (URO AJ82856). It has the P65 Warnings.ca.gov (Cancer and Reproductive Harm).
I need to know what kind of gloves should I have to handle this product and how to safely dispose
of the old seals. I do not want anyone to be harmed by this product.
Old May 9, 2024 | 12:41 PM
Jhartz's Avatar
trash can (or as the other guys call it: bin it).
Old May 10, 2024 | 07:30 AM
jrb53's Avatar
Default Oil seepage
It take a minute to replace use a pick to lift it out clean off oil and replace
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
