Oil Sender/switch which one to buy
Old Jul 20, 2019 | 04:58 AM
Dutchy's Avatar
Default Oil Sender/switch which one to buy
Hi all
firstly my Jag fire first turn over just using the key only about 3 sec and she starts
anyway I an buying bit here and there, MAF sensor hoses senders, serpentine belt ect just to replace as all I am sure are old, and as I go for 800klm drives don't want a breakdown.
so the oil sender I purchased is AJ8 4853 this is a 60psi sender/switch XJ8 X1998-2003 XJR 1997-2003
other part numbers are C31177 60psi & C15474 100psi sender/switches I think are for E-Type and V12 engines
so the question is which one?
Old Jul 20, 2019 | 08:25 AM
motorcarman's Avatar
Just like all Fords, Jaguars use an oil pressure SWITCH, not transducers from about 1997 onward.
The older cars use the transducer.
bob
5speedusa
Mar 13, 2022 07:17 AM
GvilleVDP
May 29, 2013 10:10 AM
J_C_R
Dec 30, 2012 06:55 PM
maxbaby
General Tech Help
Nov 5, 2008 09:38 AM
