P0446 Error Code / Problem Filling Gas
Old Aug 6, 2012 | 11:01 PM
holybananas's Avatar
Default P0446 Error Code / Problem Filling Gas
Hey Everybody,
Just after paying $2,700 to have the transmission repaired on my XJ8, I went to fill her up with gas and to my surprise she wouldn't take any gas. The car would only take a few dollars and stop as if it were full, and in some cases overflow out of the gas tank.
If I tap the charcoal canister before going to fill up the car will take fuel like a charm, if you don't then it won't take any gas. I'm assuming a valve is stuck closed and when tapped it will open.
The car is giving a P0446 code (Evaporative Emission Systems Vent Control Circuit) and I'm not sure exactly what I need to buy and replace.
Do I need a whole new charcoal evap cannister, or is it the purge valve/vapor canister control?
Any help would be much appreciated!
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
alpecsa
Sep 7, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
