Paint repair
Old Dec 2, 2025 | 10:15 PM
franky90's Avatar
Default Paint repair
Looking to get opinions, if this is something I can fix myself, or if it'd require taking it to a shop.
Part of hood looks dull, roof looks abysmal.
-Frankie.
Old Dec 2, 2025 | 11:21 PM
Parker 7's Avatar
Dude , that's my car
There is a 2 part mix rattle can clear coat from the well known Chicago car restoration company named .................Eastwood
To prepare surface before applying , sand off clearcoat with a non petrolium / oil / way based abrasive medium such as ......................................
There should be a gloss clear , see video link on their page
Eastwood 2K Clear Coat Spray Can Aerosol
Now the practice from those who have used it.......................
old -2k-aerosol-spray-paint-can
This company out of England
old-2k-aerosol-spray-paint-can-yourspraypaints - Premium Custom Filled Aerosols | Your Spray Paints
Old Dec 3, 2025 | 10:14 AM
RandyS's Avatar
Getting the damaged clear coat off without damaging the top coat is an arduous process.
It can be done, it just takes a lot of time, energy, and most of all patience. There may be
products available today, that make it easier.
Old Dec 3, 2025 | 12:34 PM
Parker 7's Avatar
Knowing to not take much off the base coat color ( just to remove oxidation , if that is possible, and still leave enough base coat ) can you use a rounded pillow shape abrasive holder and watch for color change being left on abrasive pillow ?
I severally damaged my clearcoat using a too strong clothing detergent to cut wax and get to a no wax observation to come up with a good observation , base coat oscitation accrued after clear coat sections came off over periods of time
Left strong soap on too long as was dealing with illness
Old Dec 3, 2025 | 05:01 PM
Peter_of_Australia's Avatar
In a painfully arduous process I once managed to remove the complete clear coat layer on my X-Type (careful use of a cutter knife mainly and water pressure cleaner) - without damaging the paint.
Then successfully applied new clear coat.
Now my bonnet (hood) shows similar signs. I helped off the first bits of clear coat flakes with a water pressure cleaner. It will take a while for the rest to follow, especially as the car is currently not used and under cover. The UV light of the sun would help to remove the rest more easily....
But in regards of the pictures shown in the initial post/question above: The damage is not big enough yet. Maybe there is a chemical way, about which I do not know, to remove the old clear coat layer WITHOUT damaging the paint underneath, but I'd assume that a complete sand off, base coat, paint and clear coat "operation" is required here.
Old Dec 4, 2025 | 06:55 AM
RJ237's Avatar
If the base coat were non metallic it would be possible to remove the clear coat with wet 800 grit and respray clear coat. But with metallic base coat the sanding would change the appearance of the paint and it would be necessary to respray the base coat.
RJ
Old Dec 4, 2025 | 12:54 PM
RandyS's Avatar
I was using a combination of 40 micron abrasive along with an older style liquid
rubbing compound. If one is VERY careful the clear coat can be removed however
once removed the reflection of the paint changes in that area. Using a good paint booth
is required to even get close to the original paint reflection. In truth, sanding it down and
a respray would be far less labor intensive.
Old Dec 6, 2025 | 01:23 PM
clubairth1's Avatar
Community Influencer
Sorry the paint has failed and the only solution is to sand it off and repaint.
All these half-*** methods will look exactly like that.
Old Dec 6, 2025 | 03:25 PM
Jhartz's Avatar
Said another way: go see a professional
Old Dec 6, 2025 | 08:20 PM
RandyS's Avatar
Ditto
Old Dec 7, 2025 | 01:03 PM
Parker 7's Avatar
I was looking to get by on my 1996 X300 ( not original thread opener ) with minimum effort / cost on clear coat peeling but may not be the case
Paint and clear was gorgeous until put too strong a soap to get to pure clearcoat and no residuals of wax
My paint is an original Jaguar color code X Nautical named mica version / type ( Blue / Green turns in sunlught )
Do like the suggestions of pressure washer to aid to an extent as never thought of that
Wondering if mica falls under the same consideration as metallic in sanding prep
If not I now know to go with a new base coat of my choice
Old Dec 12, 2025 | 05:19 PM
I just stumbled across a youtube video, which shows, how to repair such a damage:
It's in German (which I understand, but you probably wouldn't), but that does not matter, because the pictures speak for themselves. He also chose a new paint-approach, starting with 2 layers of primer.
Old Dec 17, 2025 | 11:44 AM
Silverjag0's Avatar
That's clear coat failure try sanding it with 2000 grit till its flat and then use polishing compound but it may eat up more clear and still look dull . That's large part of the car its possible to paint it with cans but don't expect showroom results . If you have air compressor the diy it but you should know what you're doing . Otherwise just find shop that would fix it with reasonable price always ask for HS clear coat .
Old Dec 17, 2025 | 12:17 PM
Parker 7's Avatar
HS clear coat :
" ALEXSEAL HS Clear Coat is characterized by a high gloss appearance with wet-look effect, as required for yacht coatings. The special product properties reduce the cleaning and maintenance effort and increase the "
Not cheap
See file below
trkyam
Jun 29, 2025 03:42 PM
bagpype
Mar 24, 2024 06:57 PM
Some Day, Some Day
Detailing / Car care
Mar 15, 2019 12:26 AM
Daf11e
Jan 15, 2017 10:12 AM
NorJag
Jun 7, 2016 11:21 AM
