part load breather
Old Apr 1, 2008 | 06:09 PM
skanoski's Avatar
Default part load breather
this is sort of carried over from the PCV/oil post, where it was suggested to me to replace my part load breather hose.
I'm waiting on the part; but when looking at it, this doesn't look as straightforward as one might think. I'm sure a lot of you have replaced this crummy plastic part before. Does anyone have any tips on how to do this? It's difficult to see where the hose goes from the crankcase. Can this be done by a guy in a garage who does NOT have a lift? Do you have to go at it from underneath the engine, and if so, is it do-able with just some jack stands?
Old Apr 1, 2008 | 06:38 PM
skanoski's Avatar
Default RE: part load breather
oh yeah.....it's a 98 XJR
Old Apr 1, 2008 | 06:40 PM
jag_genius's Avatar
that hose goes from the bank 2 cam cover to under intake then clips into lower throttle body then does a twirl and then goes to purge valve.. no jacks needed.. just the hardest part wud be the clipped part in the lower throttle body they sometimes brake in there and have to be picked out with a long pick. but pretty straight forward..
Old Apr 1, 2008 | 06:41 PM
jag_genius's Avatar
get at it frm the top. if its a xjr then it might be bit more difficult .
Old Apr 1, 2008 | 06:43 PM
jag_genius's Avatar
are you getting vacuum at the hose?
Old Apr 1, 2008 | 08:24 PM
skanoski's Avatar
Yes, there's vacuum---which as you may already know, is actually bad news for me. I need to replace it anyways, because it's cracked (temporarily sealed with a poxy). It's looks like it's going to be a bitch with the supercharger in the way..
Old Apr 2, 2008 | 05:09 AM
FactoryJaguarTech's Avatar
LOL it is tougher on the R but not impossible.
Old Apr 2, 2008 | 05:24 AM
JagtechOhio's Avatar
Hey Skan,
Why bother? Sounds like your Poxy is going to last longer then Mahle's Nikasil.
Try tieing a piece of string around the old one, if you pull it out. Changing bits like that is always easier if you snake them.
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Feb 21, 2023 04:29 AM
TXJagR
Jun 20, 2016 01:02 PM
perfectson
Nov 1, 2015 10:46 AM
nitrolouie2142
Sep 5, 2015 01:55 PM
