parts with vin #
Old Jan 24, 2018 | 09:36 AM
jaguar jon02's Avatar
Default parts with vin #
have 2 2001 xj8's , one wrecked one not . wrecked one runs good other has bad comp. changed out the key switch ,comp ,transponder,theift module, everything ele i can think of. says wrong part installed and want start.
what else has vin # in it
Old Jan 24, 2018 | 10:10 AM
avern1's Avatar
It isn't a matter of VIN it is the software programming and has to be done with dealer level computer. Either dealer or independent Jag specialist. The parts are not able to communicate with the network.
Old Jan 25, 2018 | 09:29 AM
Don B's Avatar
Hi jaguar jon02,
Vern has given you an excellent reply despite the difficulty of reading your post.
You can help yourself and help the rest of us by proof-reading your messages before you hit Submit. Others will be better able to understand your issues and help if you use correct spelling, capitalization and punctuation, and avoid using abbreviations that can have multiple interpretations. For example, does "comp." mean component, compressor, or computer?
Cheers,
Don
Old Jan 30, 2018 | 05:17 AM
thanks don but i figured that anyone that knows the system would know that comp would mean computer and not the compressor as part of the starting system. as i changed over everything ,what would need to be programmed. all the parts should be matched from the other car.?
Old Jan 30, 2018 | 07:37 AM
Originally Posted by jaguar jon02
..... wrecked one runs good other has bad comp. .....
thanks don but i figured that anyone that knows the system would know that comp would mean computer .....
When I first read your post I took "comp" to mean compression. Abbreviations other than standard acronyms can often be misleading.
As Vern explained, you can't just switch compatible hardware. Many modules aren't plug & play. They need to be programmed with Jaguar diagnostics to function.
Changing many parts together will make the task of troubleshooting and configuring more difficult.
Old Jan 30, 2018 | 09:14 AM
Don B's Avatar
Hi jaguar jon02,
FYI, Jaguar service documentation rarely uses the term "computer" in reference to any component. The most common term is "control module," as in Engine Control Module, Transmission Control Module, Key Transponder Module, Security and Locking Control Module, etc. Occasionally the term "control unit" is used, and on the XJ40s what was later known as the Body Processor Module was called the Central Microprocessor (CPU). Using terms consistent with Jaguar's service documentation helps us avoid confusion.
If you click on the Search tab above and select Advanced Search, you can search the forum for relevant information.
Here are some links may be helpful - I'm sure there are many more in the forum:
VCATS Listing - How To Use It
Security Locking Control Module - FIXED
Recoding Remote Alarm Transmitters FAQ
Stolen Keys X308 1999 Reprogrammed - RESOLVED
Remote Key Fob Button Repair
Jaguar X308 Electrical Guide 2001
Jaguar Electronic Parts Catalog Download & Installation Instructions
Jaguar Technical Information System JTIS Download & Installation Instructions
Jaguar X308 Electrical Troubleshooting by avt007
Jaguar X308 DTC Summaries Guide 2001
Cheers,
Don
etaent
Aug 22, 2014 07:55 AM
2004XJ8
General Tech Help
Apr 11, 2008 05:59 PM
earl08
Mar 24, 2008 08:14 PM
1987XJ6
May 21, 2007 06:57 PM
Apr 17, 2007 11:52 AM
