Passengers door open, but it's not
Old Jan 26, 2020 | 03:48 PM
CraigMc's Avatar
Default Passengers door open, but it's not
So I've read up on this and have assumed a faulty microswitch but now I'm not so sure. Car is a 98 xjr. A few nights ago I was woken up by the alarm, which I traced back to the car thinking a door is open. After open and closing all doors it seemed to go away, but then the alarm went off in the work car park the following day.
Working on the basis the door ajar/open microswitch has gone I've had the door cards each passenger door (front and back) and unclipped the miltiplug that goes to the latch. Felt very pleased with myself as I shut the last door and locked the car, only to see the interior light still on key in the ignition, same warning message, passengers door open.
Anyone care to explain this? From.what I understand, that warning should only light when the circuit is complete, by disconnecting the whole unit, surely the car can't see a complete circuit?
Anyone able to point me in the right direction to resolving this?
Thanks,
Craig
Old Jan 26, 2020 | 04:17 PM
motorcarman's Avatar
ONE of the door circuits is the fault. (there are 3 passenger doors)
You can go to the security module and interrogate for LAST ALARM ACTIVATION to see what the SLCM determined to be the fault.
You will need dealer level diagnostics but the DTC is probably there.
bob
Old Jan 27, 2020 | 06:04 AM
CraigMc's Avatar
Cheers, I guess theres theres now way to get that level of detail otherwise? My most pressing issue is how can the alarm still be triggered if I've reset with the key, disarmed and then disconnected the wiring for each of the passenger door latches? Is there another circuit I'm not aware of?
Thanks,
Craig
Old Jan 27, 2020 | 09:07 AM
Diver's door and boot lid??
bob
Old Jan 28, 2020 | 04:19 PM
CraigMc's Avatar
Fraid not, with either the drivers door or boot open it cycles through a warning for that and the passenger door...
giandanielxk8
Nov 28, 2019 09:08 PM
Haydedps
Jun 30, 2019 10:15 PM
dragonalfa
Nov 30, 2016 05:44 AM
yeldogt
Apr 10, 2011 10:06 AM
squish
Nov 22, 2010 05:52 PM
