Play on rear wheel
Old Feb 25, 2024 | 09:43 AM
pcolapacker's Avatar
Default Play on rear wheel
Left rear wheel has play. Side to side just can hear. Top to bottom maybe 1/16". Right side rock solid. No movement or sound. I understand this is the wheel bearing. Was going to switch entire rear end from my parts car until figured out it's driver's side also has some play. Can't see it move. Just hear it click. Although less play on parts car, not worth the trouble of switching. Questions: Is this 1/16" play an issue if I frequently check it? When they go bad, is it a slow process or quick failure?
Old Feb 25, 2024 | 03:20 PM
motorcarman's Avatar
More than likely the lower fulcrum bearings if there is no 12-6 o'clock play but only 3-9 o'clock.(wheel bearings are loose all the way around)
Old Feb 29, 2024 | 02:29 PM
@motorcarman Is the attached what you're referring to as the lower fulcrum bearings.
File Type: pdf
Old Feb 29, 2024 | 07:46 PM
The 'pivot-pin' assy. is the fulcrum bearing assy I am referring to.
Bikergonebald
Aug 7, 2022 10:05 AM
Dmcr
Dec 15, 2021 03:29 AM
WinterJag
Dec 1, 2016 03:42 PM
cyber3d
Jan 18, 2016 04:02 PM
Bward
XJ40 ( XJ81 )
Jul 5, 2009 07:23 AM
