Plug Identifier in Trunk(Boot)
Old Jun 24, 2021 | 04:54 PM
chriselley's Avatar
Default Plug Identifier in Trunk(Boot)
1998 XJ8 ( 308).
Has anyone have a way of identifying the various Plugs that are under the trunk fuse box., I'm trouble shooting the fuel pump power,.leaving here on BT11-1...... but there are about 4 plugs under the fuses and none Identified. Thanks Chris Elley ( oh yes its a long story )
this is the underside of the fusebox
Old Jun 24, 2021 | 07:55 PM
cat_as_trophy's Avatar
Forgive me stating the obvious but, after 50 years of experience on these issues, the colour codes of wires are your friend. Even with challenged eyesight now, I reckon I could find your wire among that viper's nest in about 15 seconds. Many here would do so in less than 10. The good news is some great advice you will come to treasure . . . photocopy the wiring codes (electrical guide in Stickys), laminate and stick inside each fuse box cover. You too will become an instant expert!
Cheers,
Old Jun 25, 2021 | 02:32 PM
chriselley's Avatar
Hello "cat_as_trophy"...........intersting handle, Cheers. I wrung out the wiring to fuel pump #1.........turns out BT11, was the WHITE connector.. I am presently wiring in an "in-line" fuel pump to see if I can avoid dropping the tank. Going to test hopefully this afternoon................( Will look for said Stickies)
Old Jun 26, 2021 | 03:32 AM
Hahaha . . . handle brings occasional comments!
First entrant to Ken's Catastrophic Cattery was in 1969 . . . the wolf in sheep's clothing as per my avatar.
I like the spirit of your reply, and draw attention also to the great resources, especially wiring diagrams by specific model & year, offered by Gus at <jagrepair.com>.
Chris . . . especially around fuse boxes, and especially if chasing wiring and connector continuity, I find that working from the wiring diagram to id the colour code, to the wiring loom in front of you, is fast and less confusing. You hint at a "long story". Most of us here love a good story (provided it's not too scary!) so do share . . .
Best wishes, and keep us posted,
Old Jun 26, 2021 | 01:12 PM
Garethster's Avatar
I’ve been poking around in the “Stickies” looking for the referenced “Electrical” but have come up empty handed. Does anyone ha e a direct link I can click on that would take me to the correct stickie?
TIA
Old Jun 27, 2021 | 12:39 AM
M. Stojanovic's Avatar
You can get them here (choose the year) - JagRepair.com - Jaguar Repair Information Resource
Old Jun 28, 2021 | 10:56 AM
Jhartz's Avatar
Default 98 Electrical guide
attached OOPS: FILE SIZE EXCEEDS FORUM 5MB LIMIT. SEND ME YOUR EMAIL AND I WILL EMAIL IT TO YOU. jameshartz@***.net
Jagger98
Dec 11, 2021 05:21 AM
timsalyer
Jun 22, 2014 07:53 AM
jagosaurus
Mar 27, 2013 06:17 PM
Stoney1
Oct 19, 2012 08:32 PM
