Pollen filters
Old Aug 9, 2025 | 03:58 AM
Mark waite's Avatar
Default Pollen filters
Could any one please let me know if there is a pollen filter on a 2002 Jaguar xj8. And where to find it as I have had conflicting views on the internet. Many thanks mark
Old Aug 9, 2025 | 07:52 AM
Peter_of_Australia's Avatar
I actually cannot remember, if I did change the cabin air filter on my 1998 X308. But I found a video, which suggests, it shows where the cabin air filter for a 2002 Xj8 is:
Thus, I'd say, if your cabin air filter is there, you found it, if not, you may not have one...
Old Aug 9, 2025 | 08:09 AM
motorcarman's Avatar
Here it is again!
If you did not fit one decades ago, you are out of luck.
File Type: pdf
Old Aug 9, 2025 | 08:33 AM
Mark waite's Avatar
Thank you very much for your kind replies, but I think the video is not from an xj as bonnet opens the wrong way. Yours with thanks. Mark
Old Aug 9, 2025 | 08:39 AM
Mark waite's Avatar
Could you please tell me where the pollen filter is located on an xj8 2002 thank you very much
Old Aug 9, 2025 | 09:29 AM
The video is for the XJ8 (NEW XJ=X350)
Old Aug 9, 2025 | 04:02 PM
Addicted2boost's Avatar
Mark, there is no cabin filters available for the X308 platform.
Old Aug 9, 2025 | 05:17 PM
Ken Cantor's Avatar
They may be NLA from Jaguar et al but there may be a manufacturer in Mark’s area that could fabricate one for him whether or not he has the original “frame”. This an Edmonton based firm:
https://bgecleanair.com/about-us/
Their focus is commercial HVAC systems where custom fabrication is often needed at competitive prices.
Old Aug 9, 2025 | 10:02 PM
Very interesting Ken. One thing that is odd about the X308 cabin air filter location (when they had them) is that even though you have to pull the cowl panel to replace it, but the very ends of the cowl panel is wide open so that water and debris can drain out. So like many other things in life including air, it takes the path of least resistance which means that it will largely bypass the cabin filter and pull the unfiltered air into the cabin.
Old Aug 9, 2025 | 11:04 PM
Mark waite's Avatar
Default Pollen filters on x308
Thank you very much to everyone that has contributed to this problem I think it is time to give up my search for the elusive pollen filter.
Old Aug 14, 2025 | 02:31 PM
Jaaag00xj8's Avatar
2001 and newer may have a pollen filter that is under the hood in a panel at the firewall.
Old Aug 14, 2025 | 02:39 PM
Mark waite's Avatar
Hi jaag
after extensive searches I am led to believe that the x308 does not have a pollen filter. I now believe the problem is one of the blower mothers or resistors is the problem and it is booked into the garage on Monday morning. So after that I should have a definitive answer to this thread which I will report on here hopefully to help others with this problem
many thanks mark
Old Aug 14, 2025 | 07:51 PM
RandyS's Avatar
1998-2009 Jaguar XJ8 Cabin Air Filter - Autopart Premium APCAF196 - PartsGeek.com
mark1096
General Tech Help
May 18, 2021 03:00 PM
Jaguar George
Oct 27, 2017 01:41 PM
Eddie602
Jun 15, 2017 03:56 PM
Jagst
Feb 20, 2016 05:25 AM
Newby
Feb 23, 2012 09:51 PM
