Is it possible to disconnect the valet button?
Old Apr 21, 2018 | 02:10 PM
FinnJag's Avatar
Default Is it possible to disconnect the valet button?
I do not have problem with Valet... yet. Problem is that master key is cut into the trunk lock. I can not take the part of the key away. No problem yet.. it has been like that for a while and all works fine until somebody will press valet button. Therefore I would like to know, is it possible to disconnect the whole function? It is so unnecessary function. Does it work if I just unplug the button or do I get some error codes then?
I have XJ8 1998.
Old Apr 21, 2018 | 03:44 PM
avern1's Avatar
No reason you shouldn't be able to unplug it. It is a Normal Open Circuit switch, pushing the button closes the circuit. Removing the plug would still be an open circuit.
Old Apr 22, 2018 | 02:22 AM
FinnJag's Avatar
OK. Then it should be a simple solution. Thanks!
Loxmth
Jun 22, 2016 07:56 PM
Johnken
Mar 10, 2016 08:21 PM
LedZepplin
Jul 24, 2011 09:19 PM
swampy
Nov 16, 2010 03:41 PM
tgds932001
May 19, 2010 02:04 PM
