Possible Faulty Brake Switch
2003 Jaguar Xj8; 120,000 miles
Intermittent lack of cruise control, failsafe engine mode message not on.
After trying for cruise control enough, the failsafe engine mode message will appear and cruise control will be completely gone.
No DTCs and the message disappears when the car is restarted.
Brake lights turn on and off as expected.
I believe this is a faulty brake switch, but someone please confirm my diagnosis.
Also, is there a way to test the brake switch with a multimeter before I aim the parts cannon at a potentially innocent component.
Don't trust just using a multimeter on the brake light switch. Mine tested fine, but replacement cured the car dropping into failsafe mode & disabling the throttle when the cruise control was 'armed'.
I saw a thread on here recently that said resoldering the microswitches to the board in the switch normally fixes the issue. I've not tried it on mine, but will as I kept the old switch because I couldn't prove a fault on it with my meter.
